CRS317 running hot
Just got a new CRS317, did the firmware update to 6.48.4 (stable), nothing is connected to the switch except for management eth.
the switch is already running hot.. CPU is at 74C.
cpu-temperature: 74C
       psu1-state: ok
       psu2-state: fail
       fan1-speed: 7830RPM
       fan2-speed: 7620RPM
Is this normal ?
I saw others on this forum running coller than this.
What can I check in the event that this is not normal ?
Thanks :slight_smile:
74°C is quite HOT …
Question 1 :
How many and what kind of SFP+ interfaces are you using ?
If you have any Module with onboard Temp-Monitoring , how HOT are they ?
Question 2:
Where is your Router?
In the middle of the sahara desert facing the sun? =)
Thats just it, nothing is connected to the sfp ports yet and its my office righr now… at 23C room temperature.
I did a full config reset and its lile that out of the box.
Also took a look qnd the cpu is completely idle at 0-1%
Try to Update / downgrade to the Long-term release.
It may be a BUG in the 6.48.4 (stable)
My CRS317 with ambient temp at 25C and running 6.48.4 (with updated firmware) has a cpu temp of 47C and overall temp of 51C. This includes one 10GbaseT copper adapter and 9 SFP+ DACs. The CPU is between 2-3% utilization. My fans never run (except on reboot of course)
I have a feeling that something was knocked loose during shipping.
Did a downgrade to 6.47.10(long-term) and nothing changed.. its even worst now.. i’m getting 79C temps.
Could the heatsink compound be missing ? because the heatsink fins in the back are dead cold. i’m not sure that heat is getting through.
Any more ideas that I could test ?
Thanks guys
Thanks, that was the problem. I opened the case and the heatsink was loose on the chip.. all 4 screws were not screwed in.
Now the ARM chips runs at 34C, no fans, and the back heatsink is getting warmer !
That did the trick ! :slight_smile:
