CRS317 Stuck at ~1Gb/s
we have a CRS317 connected via SFP+ fiber (Allnet / Ubiquity / Intel (server side)) and different Broadcom NICs. Iperf3 tests shows, that I can’t get over 1Gb and so I asking for help. Maybe there is a configuration issue.
The configuration looks like:
# jan/26/2021 13:08:40 by RouterOS 6.47.4
# software id = M7UZ-9NNP
# model = CRS317-1G-16S+
set [ find default-name=ether1 ] comment=management
set [ find default-name=sfp-sfpplus1 ] comment=fra-test-san speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] comment=fra-test-pmox-06 speed=10Gbps
set [ find default-name=sfp-sfpplus3 ] comment=fra-test-pmox-07 speed=10Gbps
set [ find default-name=sfp-sfpplus4 ] comment=fra-test-pmox-06 speed=10Gbps
set [ find default-name=sfp-sfpplus5 ] comment=fra-test-pmox-07 speed=10Gbps
set [ find default-name=sfp-sfpplus6 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus7 ] comment=fra-test-pmox-03
set [ find default-name=sfp-sfpplus8 ] comment=frei
set [ find default-name=sfp-sfpplus9 ] comment=fra-test-pmox-08 speed=10Gbps
set [ find default-name=sfp-sfpplus10 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus11 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus12 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus13 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus14 ] comment=frei speed=10Gbps
set [ find default-name=sfp-sfpplus15 ] comment="Cross connect"
set [ find default-name=sfp-sfpplus16 ] comment=hp-stack
add admin-mac=D2:xx:xx:xx:xx:xx auto-mac=no name=core-lan vlan-filtering=yes
add name=management
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/interface bridge msti
add bridge=core-lan identifier=1 priority=0x1000 vlan-mapping=800,900,701,702
add bridge=management comment="management interface" interface=ether1
add bridge=core-lan comment=fra-test-san edge=yes interface=sfp-sfpplus1
add bridge=core-lan comment=fra-test-pmox-06 edge=yes interface=sfp-sfpplus2
add bridge=core-lan comment=fra-test-pmox-07 edge=yes interface=sfp-sfpplus3
add bridge=core-lan comment=crossconnect edge=yes interface=sfp-sfpplus15
add bridge=core-lan comment=hp-stack edge=yes interface=sfp-sfpplus16
add bridge=core-lan interface=sfp-sfpplus6
add bridge=core-lan interface=sfp-sfpplus4
add bridge=core-lan interface=sfp-sfpplus5
add bridge=core-lan interface=sfp-sfpplus8
add bridge=core-lan interface=sfp-sfpplus7
add bridge=core-lan comment="DMZ fortigate" interface=sfp-sfpplus14
add bridge=core-lan comment="fortigate LAN" interface=sfp-sfpplus13
add bridge=core-lan comment=fra-test-pmox-08 interface=sfp-sfpplus9
set discover-interface-list=none
/interface bridge vlan
add bridge=core-lan comment="internal LAN" tagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus6,sfp-sfpplus16,sfp-sfpplus5,sfp-sfpplus13,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9 vlan-ids=701
add bridge=core-lan comment="DMZ LAN" tagged=sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus16,sfp-sfpplus14,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9 vlan-ids=702
add bridge=core-lan comment="deployment LAN" tagged=sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus16,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9 vlan-ids=800
add bridge=core-lan comment="SAN storage" tagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus15,sfp-sfpplus9 vlan-ids=900
add address=10.10.10.4/24 interface=management network=10.10.10.0
set servers=172.25.25.5
add distance=1 gateway=10.10.10.10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system routerboard settings
set boot-os=router-os
We have a copper crossconnect with a S+RJ10 to a second CRS317 (for failover) and a uplink to a HP-Stack (1GB) also with a S+RJ10.
A short test looks like:
Connecting to host 10.2.0.11, port 5201
[  5] local 10.2.0.18 port 57218 connected to 10.2.0.11 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   182 MBytes  1.53 Gbits/sec   41    312 KBytes
[  5]   1.00-2.00   sec   181 MBytes  1.52 Gbits/sec   50    336 KBytes
[  5]   2.00-3.00   sec   180 MBytes  1.51 Gbits/sec   31    252 KBytes
[  5]   3.00-4.00   sec   181 MBytes  1.52 Gbits/sec   23    250 KBytes
[  5]   4.00-5.00   sec   155 MBytes  1.30 Gbits/sec   36    341 KBytes
[  5]   5.00-6.00   sec   100 MBytes   843 Mbits/sec    0    523 KBytes
[  5]   6.00-7.00   sec   102 MBytes   854 Mbits/sec    4    502 KBytes
[  5]   7.00-8.00   sec   102 MBytes   853 Mbits/sec   16    458 KBytes
[  5]   8.00-9.00   sec  99.8 MBytes   837 Mbits/sec    0    602 KBytes
[  5]   9.00-10.00  sec  99.9 MBytes   838 Mbits/sec    8    559 KBytes
[  5]   0.00-10.00  sec  1.35 GBytes  1.16 Gbits/sec  209             sender
[  5]   0.00-10.00  sec  1.35 GBytes  1.16 Gbits/sec                  receiver
iperf Done.
[  5] local 10.2.0.18 port 57226 connected to 10.2.0.11 port 5201
[  5]   0.00-1.00   sec  95.0 MBytes   797 Mbits/sec   33    254 KBytes
[  5]   1.00-2.00   sec  96.9 MBytes   812 Mbits/sec    0    462 KBytes
[  5]   2.00-3.00   sec  96.6 MBytes   810 Mbits/sec   19    297 KBytes
[  5]   3.00-4.00   sec  95.5 MBytes   801 Mbits/sec   58    295 KBytes
[  5]   4.00-5.00   sec  95.6 MBytes   802 Mbits/sec   30    268 KBytes
[  5]   5.00-6.00   sec  94.2 MBytes   790 Mbits/sec    3    369 KBytes
[  5]   6.00-7.00   sec  95.9 MBytes   805 Mbits/sec    2    384 KBytes
^[[A[  5]   7.00-8.00   sec  96.2 MBytes   807 Mbits/sec   46    230 KBytes
^[[A^[[A[  5]   8.00-9.00   sec  95.3 MBytes   800 Mbits/sec  107   91.2 KBytes
[  5]   9.00-10.00  sec  95.1 MBytes   798 Mbits/sec    2    277 KBytes
[  5]   0.00-10.00  sec   956 MBytes   802 Mbits/sec  300             sender
[  5]   0.00-10.00  sec   955 MBytes   801 Mbits/sec                  receiver
iperf Done.
We don’t use MTU 9000 yet, because I had trouble mit Corosync (Proxmox). If I do the iperf, “bridging” and “networking” has the highest CPU usage.
#     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ;;; management interface
       ether1        management        yes    1     0x80         10                 10       none
 1     ;;; fra-test-san
       sfp-sfpplus1        core-lan        yes    1     0x80         10                 10       none
 2     ;;; fra-test-pmox-06
       sfp-sfpplus2        core-lan        yes    1     0x80         10                 10       none
 3     ;;; fra-test-pmox-07
       sfp-sfpplus3        core-lan        yes    1     0x80         10                 10       none
 4     ;;; crossconnect
       sfp-sfpplus15        core-lan        yes    1     0x80         10                 10       none
 5     ;;; hp-stack
       sfp-sfpplus16        core-lan        yes    1     0x80         10                 10       none
 6     sfp-sfpplus6        core-lan        yes    1     0x80         10                 10       none
 7     sfp-sfpplus4        core-lan        yes    1     0x80         10                 10       none
 8     sfp-sfpplus5        core-lan        yes    1     0x80         10                 10       none
 9     sfp-sfpplus8        core-lan        yes    1     0x80         10                 10       none
10     sfp-sfpplus7        core-lan        yes    1     0x80         10                 10       none
11     ;;; DMZ fortigate
       sfp-sfpplus14        core-lan        yes    1     0x80         10                 10       none
12     ;;; fortigate LAN
       sfp-sfpplus13        core-lan        yes    1     0x80         10                 10       none
13     ;;; fra-test-pmox-08
       sfp-sfpplus9        core-lan        yes    1     0x80         10                 10       none
Any suggestions ?
Update
Found the reason: HW offload was enabled for the management bridge, so that it wasn’t possible to enable on core-lan. Disable it on management solves the problem:
[  5] local 10.2.0.18 port 57364 connected to 10.2.0.11 port 5201
[  5]   0.00-1.00   sec  1.10 GBytes  9.48 Gbits/sec    0   1.58 MBytes
[  5]   1.00-2.00   sec  1.10 GBytes  9.47 Gbits/sec    0   1.74 MBytes
[  5]   2.00-3.00   sec  1.10 GBytes  9.46 Gbits/sec    0   1.74 MBytes
[  5]   3.00-4.00   sec  1.08 GBytes  9.30 Gbits/sec    0   1.74 MBytes
[  5]   4.00-5.00   sec  1.10 GBytes  9.47 Gbits/sec    0   1.74 MBytes
[  5]   5.00-6.00   sec  1.10 GBytes  9.46 Gbits/sec    0   1.74 MBytes
[  5]   6.00-7.00   sec  1.10 GBytes  9.47 Gbits/sec    0   1.74 MBytes
[  5]   7.00-8.00   sec  1.10 GBytes  9.46 Gbits/sec    0   1.74 MBytes
[  5]   8.00-9.00   sec  1.10 GBytes  9.47 Gbits/sec    0   1.74 MBytes
[  5]   9.00-10.00  sec  1.08 GBytes  9.30 Gbits/sec    0   1.74 MBytes
[  5]   0.00-10.00  sec  11.0 GBytes  9.43 Gbits/sec    0             sender
[  5]   0.00-10.00  sec  11.0 GBytes  9.43 Gbits/sec                  receiver
iperf Done.
Solution / reson found here: https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#Bridges_on_a_single_switch_chip
