CRS317 - want SwOS, but won't boot
Same issue here
Just bought the switch and decided to give the SwOs a try and same thing happend
After the restart it is looping and looping
Any solution to this ?
How can i switch to RouterOs without serial cable becouse i dont have any with me
thank you
Same problem here on new CRS354.
Might be the same thing, I have a new crs305-1g-4s+in if I boot the unit, and use winbox and change the router board to boot SwitchOS, clikc Apply, and then reboot - I cannot access it again until I power off the box, then hold the reset button while applying power until the light above the person icon is flashing. Then I wait a few a minutes and can access it again in RouterOS. Really wish I could use it in switch mode.
