I am having an issue.. I do events and at times we have to ration out internet at certain rates.. I was at first going to use the Router (CCR2116) to handle Queues.. But it turns out that im just going to Layer2 them one of the publics.. So now that is not an option.. I did try and Use the egress/ingress area in the
section of router OS.. but when I end
150M by 150M it only really works on the Egress. on the ingress I have to set it 600 to 700M in order to get the results im looking for.. which is the 150M
I’ll port my config.. it’s not actually on this switch but all the switches are pretty much configured the same but I have this problem on all of them. Im more adding my config to show that I have the bridge set up properly for hardware offloading.
Thank you !
add comment=defconf dhcp-snooping=yes name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=defconf disabled=yes poe-out=off
set [ find default-name=ether2 ] comment="" disabled=yes poe-out=off
set [ find default-name=ether3 ] comment=defconf disabled=yes poe-out=off
set [ find default-name=ether4 ] comment=defconf disabled=yes poe-out=off
set [ find default-name=ether5 ] comment=defconf disabled=yes poe-out=off
set [ find default-name=ether6 ] comment=defconf disabled=yes poe-out=off
set [ find default-name=ether7 ] disabled=yes poe-out=off
set [ find default-name=ether8 ] disabled=yes poe-out=off
set [ find default-name=ether9 ] disabled=yes poe-out=off
set [ find default-name=ether10 ] disabled=yes poe-out=off
set [ find default-name=ether11 ] disabled=yes poe-out=off
set [ find default-name=ether12 ] disabled=yes poe-out=off
set [ find default-name=ether13 ] disabled=yes poe-out=off
set [ find default-name=ether14 ] disabled=yes poe-out=off
set [ find default-name=ether15 ] comment=TestPort disabled=yes poe-out=off
set [ find default-name=ether16 ] disabled=yes poe-out=off
set [ find default-name=sfp-sfpplus2 ] comment=
/interface vlan
add interface=bridge name=20
add bridge=bridge comment=defconf ingress-filtering=yes interface=ether1 pvid=10 trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether2
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether3
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether4
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether5
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether6
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether7
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether8
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether9
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether10
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether11
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether12
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether13
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether14
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether15 pvid=130
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether16
add bridge=bridge comment=defconf ingress-filtering=yes interface=sfp-sfpplus1 pvid=10 trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=sfp-sfpplus2 trusted=yes
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1,sfp-sfpplus1,sfp-sfpplus2 untagged=ether15,ether16 vlan-ids=130
add bridge=bridge tagged=ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus2 untagged=ether1,sfp-sfpplus1 vlan-ids=10
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=30
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=31
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=40
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=41
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=50
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=51
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=60
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=61
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=69
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=70
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=71
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=79
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=80
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=89
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=90
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=100
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=110
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=130
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=140
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=150
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=160
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=169
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=170
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=179
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=180
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=189
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=190
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=192
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=210
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=230
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=240
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=250
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=260
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=269
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=270
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=280
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=289
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=290
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=400
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=401
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=600
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=601
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=1701
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=1702
add bridge=bridge tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=1703
/interface ethernet switch rule
add comment=Cisco-PVSTP dst-mac-address=01:00:0C:CC:CC:CD/FF:FF:FF:FF:FF:FF new-dst-ports="" ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 switch=switch1
add comment=CDP-Rule dst-mac-address=01:00:0C:CC:CC:CC/FF:FF:FF:FF:FF:FF new-dst-ports="" ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,sfp-sfpplus1,sfp-sfpplus2 switch=switch1
add address=192.1
add distance=1
set boot-os=router-os
