I notice the tx-drop counter slowly incrementing on the ethernet interface of my CRS326 running ROS/firmware 6.49.1.
To be clear, I am not experiencing any performance issues or packet loss.
I am trying to understand why I am seeing the tx-drop counter increment when I should be nowhere near exhausting the output queue on interfaces that show incrementing drops.
I am using the CRS326 as a pure switch with all interfaces bridged and HW offloaded. Flow control is disabled.
My configuration is near to default and I am not using VLANs or L3 features that would cause packets to be processed by the CPU.
I am not using any 10G → 1G connections (or any 10G at all) where tx buffer exhaustion would make sense.
iperf testing shows ~942 Mbits/sec with 0 retries.
The interface statistics on other connected devices are not showing errors/drops or any signs of buffer exhaustion.
Again I realize these are minimal drops and they are not causing any noticeable impact but I can’t help but wonder if anyone else is seeing the same behavior? The only other examples I’ve been able find involve 10G → 1G connections.
Are these drops cosmetic or the result of receiving unknown frames? I am new to Mikrotik is this simply normal operation?
I would love to hear your thoughts.
ether1 and ether2 have 100M devices connected and show no drops.
ether 23 is an uplink to an AP that doesn’t see anywhere near gigabit speeds.
ether 22 is an uplink to a HEX POE with 2 100M devices connected.
interface ethernet print stats where running
name: ether1 ether2 ether3 ether4 ether5 ether6 ether22 ether23 ether24
driver-rx-byte: 0 9 118 1 299 564 1 026 820 2 533 185 1 472 903 57 886 412 19 888 680 388 600
driver-rx-packet: 0 26 8 640 3 011 17 814 7 050 872 881 49 012 3 203
driver-tx-byte: 5 283 480 5 283 822 5 283 480 5 288 280 5 283 420 5 561 939 236 710 706 5 283 480 5 314 190
driver-tx-packet: 88 058 88 059 88 058 88 139 88 057 86 292 1 115 906 88 058 88 299
rx-bytes: 17 830 748 1 058 635 155 493 398 849 493 753 5 461 479 885 598 833 315 292 399 862 655 984 315 57 955 664 678
rx-too-short: 0 0 0 0 0 0 0 0 0
rx-too-long: 0 0 0 0 0 0 0 0 0
rx-unicast: 170 302 6 403 1 232 356 1 774 440 4 350 438 3 173 140 1 779 585 2 861 246 44 973 387
rx-broadcast: 0 15 585 80 118 104 400 26 067 1 873
rx-pause: 0 0 0 0 0 0 0 0 0
rx-multicast: 0 29 7 997 2 978 17 700 6 434 15 22 961 0
rx-error-events: 0 0 0 0 0 0 0 0 0
rx-fcs-error: 0 0 0 0 0 0 0 0 0
rx-fragment: 0 0 0 0 0 0 0 0 0
rx-overflow: 0 0 0 0 0 0 0 0 0
rx-jabber: 0 0 0 0 0 0 0 0 0
tx-bytes: 47 761 263 32 265 440 25 157 341 203 3 433 928 019 14 216 255 134 9 131 701 327 368 331 713 11 659 578 008 2 346 667 495
tx-unicast: 171 167 7 421 16 989 856 4 609 948 10 525 156 7 976 629 1 894 969 10 074 168 8 233 946
tx-broadcast: 29 387 29 375 28 804 29 310 29 271 28 406 28 924 3 328 27 530
tx-pause: 0 0 0 0 0 0 0 0 0
tx-multicast: 143 174 143 161 135 177 143 100 125 480 133 149 143 089 120 220 143 173
tx-underrun: 0 0 0 0 0 0 0 0 0
tx-collision: 0 0 0 0 0 0 0 0 0
tx-late-collision: 0 0 0 0 0 0 0 0 0
tx-drop: 0 0 18 2 12 9 3 14 14
tx-rx-64: 94 970 100 944 112 607 242 526 208 367 219 723 132 619 342 563 681 287
tx-rx-65-127: 355 926 21 585 1 471 654 1 308 899 1 226 688 2 772 267 1 825 603 3 230 494 7 605 087
tx-rx-128-255: 40 902 40 902 127 360 1 086 930 102 804 1 446 594 702 219 792 801 2 965 937
tx-rx-256-511: 4 173 4 080 41 806 663 127 72 301 527 712 1 099 211 402 034 1 142 362
tx-rx-512-1023: 17 981 18 391 101 856 975 377 79 884 155 888 65 969 268 448 1 410 272
tx-rx-1024-max: 78 502 16 539 492 2 282 997 13 358 119 6 195 678 21 361 8 071 650 39 574 964
tx-queue0-packet: 343 728 179 957 17 153 819 4 782 356 10 679 895 8 138 175 2 066 979 10 197 702 8 404 635
tx-queue1-packet: 0 0 0 0 0 0 0 0 0
tx-queue2-packet: 0 0 0 0 0 0 0 0 0
tx-queue3-packet: 0 0 0 0 0 0 0 0 0
tx-queue4-packet: 0 0 0 0 0 0 0 0 0
tx-queue5-packet: 0 0 0 0 0 0 0 0 0
tx-queue6-packet: 0 0 0 0 0 0 0 0 0
tx-queue7-packet: 0 0 0 0 0 0 0 0 0
