BootROM 1.41
Booting from SPI flash
BootROM: Image checksum verification PASSED
RouterBOOT booter 3.37
CRS326-24G-2S+
CPU frequency: 800 MHz
Memory size: 512 MiB
Storage size: 16 MiB
Press any key within 2 seconds to enter setup..
loading kernel... kernel not found
trying bootp protocol................................................................................................................................................... failed
kernel loading failed
Netinstall is not work, I try upload system-6.39.1-mipsbe.npk over ethernet(tftpd):
trying bootp protocol.... OK
Got IP address: 10.1.1.1
resolved mac address 20:CF:30:28:E0:2D
transfer started ....................................................... transfer ok, time=15.84s
setting up elf image... not an elf header
Never touched on of these new “dual boot (SwOS/ROS) beasts” yet, not even sure its mipsbe, which could explain the “not an elf header” problem (are you sure the .npk file is complete?).
Yes, npk is complete. I think need a *.bin or *.iso file with bootable filesystem inside(sqashfs?).
I cant found Force backup booter, in console only:
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
r - reset booter configuration
e - format storage
w - repartition nand
g - upgrade firmware
i - board info
p - boot protocol
j - boot os
t - do memory testing
x - exit setup
Try boot Flash Configure Mode:
Select boot device:
e - boot over Ethernet
* n - boot from NAND, if fail then Ethernet
1 - boot Ethernet once, then NAND
o - boot from NAND only
b - boot chosen device
f - boot Flash Configure Mode
3 - boot Flash Configure Mode once, then NAND
your choice: 3 - boot Flash Configure Mode once, then NAND
writing settings to flash... OK
BootROM 1.41
CRS326-24G-2S+
trying bootp protocol............... failed
trying bootp protocol........................................................................................................................................................................................................... failed
SwOS is booting normally. I upgraded this, but ROS also say “kernel not found”.
Any idea to reflash this device?
I bought CRS317 and happen the same problem. I can access via SWos but ROS not. It is giving the same error. I tried to netinstall but it is not working. Did you manage to reinstall ROS?
Thx
