I would like to install the “WiFi Wave2” package on the CRS326-24G-2S+RM to run CAPsMAN on it. Unfortunately, after uploading it to Files, it says “upgrade failed, free 8445 kB disk space for a (null)upgrade”. The Files folder is completely empty, both when looking through WinBox and when using /file print or /disk print. According to the technical specification, this device has a Storage Size of 16MB and 16MB is the minimum space required to install the WiFi Wave2 package.
So the question is simple - is there any way to install this package on this device, or do I have to run my CAPsMAN somewhere else?
