Hi friends. Whats the CRS326-24G-2S+RM switch capacity ?
can this switch providing 1gb speed per port at the same time ?
Thanks.
Sent from my SM-A705FN using Tapatalk
Thanks.
Please help.
thanks. but can this switch providing 1gb speed per port at the same time ?
“non blocking wirespeed” means that the traffic throughput is only limited by port bandwidth of the individual ports. So if you have a non-blocking wirespeed switch with, say, 8 1 Gbit/s ports, you can have 4 bi-directional streams, 1 Gbit/s in each direction, each between ports in a distinct pair, and none of those 8 streams in total will be throttled. Just bear in mind that there is also some multicast and broadcast traffic, and that if several ports receive ingress traffic which ends up at the same egress port, the bandwidth of the egress port may be insufficient and cause packet drops although the capacity of the switching fabric will not be exhausted.
Thanks for reply. I Understood
