I am experiencing problems with following simple setup:
From time to time I am experiencing NIC Link is Up/Down on the 10G connection between the server and CRS326.
NIC of the server was Mellanox ConnectX-3 CX312B and SFPs Intel FTLX8571D3BCV-IT.
I had replaced the SFPs with DAC cable - the same.
The setup works for a while and in few days dmesg on the server is filled with
NIC Link is Down
NIC Link is Up
Now I have replaces the Mellanox NIC with Intel X520-DA2 (tried with DAC and Intel SFPs) no big difference.
enp46s0f0: NIC Link is Up 10 Gbps, Flow Control: RX/TX
is prompted from time to time in server’s dmesg
I was using the CRS326-24G-2S+ with RouterOS till today, no I have changed to SwOS.
CRS326-24G-2S+ is used as a switch no configuration of the device is done.
After working for a week or two at some moment the situation is so worse that I need to reboot the server!
This is wrong settings, bug of incompatibility?
Thanks in advance !
