CRS326-24G-2S+ Switch Menu
I have begun testing the CRS326-24G-2S+ that we have received, and have noticed that there is not an extended switch menu like the other CRS devices I have set up in the past. I’m curious if these features have not been included in ARM’s ROS since they have moved over to ARM from Mipsbe for their CRS’s.
From what I can tell the only way to access switching features (Port isolation, block reverse DHCP, Etc.) is if I boot the SwitchOS, is that currently the case?
just guessing, but i think to see the secret sauce, you’ll need 6.41rc. but not in production environment!
all the previous OS-es (saw it with 6.39.2) expose a similar functionality as you see o the “small” routerboards (7xx, 2011, etc)
That’s right, a lot of stuff is being reorganized and will return in 6.41, when we will have the new hw-offload feature.
Thanks for the info, assumed it was related to the new Hardware/Current work on switching software.
I’ll be patient and happy to begin testing once it’s been released.
Is it possible to configure port isolation on CRS326-24G-2S+ running RouterOS 6.41.3?
