CRS326 24G-2S+ VLAN Problem on Ports 17-24
Good Evening,
I’ve got a problem. My Router is a RB4011 on Port 5 of the RB4011 there is the tagged port to port 1 of the CRS326.
The configuration of the CRS 326 is as following:
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no name=Switch_Bridge \
    vlan-filtering=yes
/interface vlan
add comment=Management interface=Switch_Bridge name=vlan10 vlan-id=10
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=Switch_Bridge comment="Trunk Port zum MT RB4011" interface=ether1
add bridge=Switch_Bridge comment="VLAN10 Management" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
add bridge=Switch_Bridge comment=VLAN100 frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether3 pvid=100
    admit-only-untagged-and-priority-tagged interface=ether4 pvid=100
    admit-only-untagged-and-priority-tagged interface=ether5 pvid=100
    admit-only-untagged-and-priority-tagged interface=ether6 pvid=100
    admit-only-untagged-and-priority-tagged interface=ether7 pvid=100
    admit-only-untagged-and-priority-tagged interface=ether8 pvid=100
add bridge=Switch_Bridge comment=VLAN200 frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether9 pvid=200
    admit-only-untagged-and-priority-tagged interface=ether10 pvid=200
    admit-only-untagged-and-priority-tagged interface=ether11 pvid=200
    admit-only-untagged-and-priority-tagged interface=ether12 pvid=200
add bridge=Switch_Bridge comment=VLAN300 frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether13 pvid=300
    admit-only-untagged-and-priority-tagged interface=ether14 pvid=200
    admit-only-untagged-and-priority-tagged interface=ether15 pvid=300
    admit-only-untagged-and-priority-tagged interface=ether16 pvid=300
add bridge=Switch_Bridge comment=VLAN900 frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether17 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether18 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether19 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether20 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether21 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether22 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether23 pvid=900
    admit-only-untagged-and-priority-tagged interface=ether24 pvid=900
/interface bridge vlan
add bridge=Switch_Bridge tagged=Switch_Bridge,vlan10,ether1 vlan-ids=10
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=100
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=200
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=300
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=700
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=750
add bridge=Switch_Bridge tagged=Switch_Bridge,ether1 vlan-ids=900
add address=192.168.26.8/24 interface=vlan10 network=192.168.26.0
set servers=192.168.26.1
add distance=1 gateway=192.168.26.1
/system clock
/system identity
set name=CRS326
I can connect with every port of the CRS326 and get an IP adress except the ports 17-24.
If I use the default config as a switch, I’ve got no problems with these ports.
I don’t know where the error is. Could anyone please help me.
Thanks in advance
Thorsten
PS: I tried the newest 6.48.1 and the long term 6.47.9 with no success.
Sorry, after spending hours of searching and couldn’t find anything I finally got it. The theme could be closed. Found my errror. It was just a layer 8 error.
:slight_smile:
