CRS326-24S+2Q+; Cisco 9300; D-Link DGS-1510-52X; TRUNK VLANs and DHCP
Description
Hello, my network consists of the above equipment, of which Cisco is Core, SW Mikrotik is Destribution, and D-link is an access switch.
I connected Cisco to SW Mikrotik using SPF+, everything worked, everything is great, and also with D-Link, although it was difficult.
But the problem is that the DHCP packets do not pass through Mikrotik.
I mean, if I put static on clients, then everything works, and if DHCP does not work.
And I also checked that Cisco - D-Link works well without Mikrotik with the same DHCP settings.
All Trunk and so on seem to be respected, but I’m not sure about Mikrotik.
Please help, thank you in advance.
conf.txt (7.52 KB)
