All:
I'm trying to get a bond + VLAN trunk to work with a Dell S4048T-ON and having issues. I've tested this configuration in eve-ng with a single cisco vios switch with no issue. Routeros 6.49.6.
Port sfp-sfpplus1 has a directly attached switch, untagged with an ip address on it. When I don't have the below configuration applied AND I have an IP address on the direct interface, I can ping between the two devices. sfp23 and sfp24 are the 2x10gig LACP bond, and are coming up as appropriate on both sides (Bonding_to_R2).
After removing the IP address and applying the below config, I cannot reach either Dell Switch IP address for ping at all. Thoughts?
Mikrotik:
model = CRS326-24S+2Q+
add frame-types=admit-only-vlan-tagged name=bridge1 vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] name=s1
/interface bonding
add mode=802.3ad name=Bonding_to_R2 slaves=sfp-sfpplus23,sfp-sfpplus24
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=Bonding_to_R2
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=s1
/interface bridge vlan
add bridge=bridge1 tagged=Bonding_to_R2 vlan-ids=599
Switch 1:
interface TenGigabitEthernet 1/46
description To_MT P23
no ip address
port-channel-protocol LACP
port-channel 51 mode active
no shutdown
interface Port-channel 51
description PC_Backup_P2P
no ip address
switchport
vlt-peer-lag port-channel 51
no shutdown
interface Vlan 599
description Backup_P2P
ip address 10.4.0.13/29
tagged Port-channel 12,51
no shutdown
Switch 2:
description To_MT P24
no ip address
no shutdown
no ip address
switchport
no shutdown
interface Vlan 599
ip address 10.4.0.14/29
no shutdown
