Hi There,
I have just got my new second-hand Mikrotik CRS326-24S+2Q+RM, planned to upgrade my local network to 40G.
My original network uses an “Unifi switch aggregation” 10G switch with no problem, and now I have added a “CRS326-24S+2Q+RM” Mikrotik SFP+ switch under the Unifi 10G switch,
and I found all the devices that is under the Mikrotik SFP+ switch’s local networks are unreachable, like NAS, and printer is not reachable, and ping not reasonable, but those devices are can be access to the WAN.
I have seen a lot of posts in the forum and tried to use Winbox to solve the problem but seems not luck, I have reset the Mikrotik SFP+ switch to the factory with basic configuration.
Current settings:
No vlan setting
Router - UDMpro - 192.168.1.1/24
Unifi 10G switch - 192.168.1.2
Mikrotik 10G switch CRS326-24S+2Q+RM - 192.168.1.10
NAS - 192.168.1.128
PC - 192.168.1.222
Ping from 192.168.1.222 to 192.168.1.128 is reachable, >1ms, but SMB via ip and visit via ://my-server/ is not working.
192.168.1.222 & 192.168.1.128 can access to WAN
but not LAN ( local network )
# 2024-01-28 21:51:34 by RouterOS 7.10
# software id = 6HT5-DZZ4
# model = CRS326-24S+2Q+
# serial number = D84F0DE2DF38
add admin-mac=08:55:31:E5:AE:7D auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=08:55:31:E5:AE:5D
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-DD4.0.1
set [ find default-name=sfp-sfpplus2 ] name=sfp-sfpplus2-DD4.0.2
set [ find default-name=sfp-sfpplus3 ] name=sfp-sfpplus3-DD4.0.3
set [ find default-name=sfp-sfpplus4 ] name=sfp-sfpplus4-DD4.0.4
set [ find default-name=sfp-sfpplus5 ] name=sfp-sfpplus5-DD5.0.1
set [ find default-name=sfp-sfpplus6 ] name=sfp-sfpplus6-DD5.0.2
set [ find default-name=sfp-sfpplus7 ] name=sfp-sfpplus7-DD5.0.3
set [ find default-name=sfp-sfpplus8 ] name=sfp-sfpplus8-DD5.0.4
set [ find default-name=sfp-sfpplus9 ] name=sfp-sfpplus9-DD6.0.1
set [ find default-name=sfp-sfpplus10 ] name=sfp-sfpplus10-DD6.0.2
set [ find default-name=sfp-sfpplus11 ] name=sfp-sfpplus11-DD6.0.3
set [ find default-name=sfp-sfpplus12 ] name=sfp-sfpplus12-DD6.0.4
set [ find default-name=sfp-sfpplus17 ] name=sfp-sfpplus17-DDPC.1
set [ find default-name=sfp-sfpplus18 ] name=sfp-sfpplus18-DDPC.2
set [ find default-name=sfp-sfpplus23 ] name=sfp-sfpplus23-Uplink-1
set [ find default-name=sfp-sfpplus24 ] name=sfp-sfpplus24-Uplink-2
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.1.1-192.168.1.254
# DHCP server can not run on slave interface!
add address-pool=dhcp interface=sfp-sfpplus1-DD4.0.1 name=dhcp1
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=qsfpplus1-1
add bridge=bridge comment=defconf interface=qsfpplus1-2
add bridge=bridge comment=defconf interface=qsfpplus1-3
add bridge=bridge comment=defconf interface=qsfpplus1-4
add bridge=bridge comment=defconf interface=qsfpplus2-1
add bridge=bridge comment=defconf interface=qsfpplus2-2
add bridge=bridge comment=defconf interface=qsfpplus2-3
add bridge=bridge comment=defconf interface=qsfpplus2-4
add bridge=bridge comment=defconf interface=sfp-sfpplus1-DD4.0.1
add bridge=bridge comment=defconf interface=sfp-sfpplus2-DD4.0.2
add bridge=bridge comment=defconf interface=sfp-sfpplus3-DD4.0.3
add bridge=bridge comment=defconf interface=sfp-sfpplus4-DD4.0.4
add bridge=bridge comment=defconf interface=sfp-sfpplus5-DD5.0.1
add bridge=bridge comment=defconf interface=sfp-sfpplus6-DD5.0.2
add bridge=bridge comment=defconf interface=sfp-sfpplus7-DD5.0.3
add bridge=bridge comment=defconf interface=sfp-sfpplus8-DD5.0.4
add bridge=bridge comment=defconf interface=sfp-sfpplus9-DD6.0.1
add bridge=bridge comment=defconf interface=sfp-sfpplus10-DD6.0.2
add bridge=bridge comment=defconf interface=sfp-sfpplus11-DD6.0.3
add bridge=bridge comment=defconf interface=sfp-sfpplus12-DD6.0.4
add bridge=bridge comment=defconf interface=sfp-sfpplus13
add bridge=bridge comment=defconf interface=sfp-sfpplus14
add bridge=bridge comment=defconf interface=sfp-sfpplus15
add bridge=bridge comment=defconf interface=sfp-sfpplus16
add bridge=bridge comment=defconf interface=sfp-sfpplus17-DDPC.1
add bridge=bridge comment=defconf interface=sfp-sfpplus18-DDPC.2
add bridge=bridge comment=defconf interface=sfp-sfpplus19
add bridge=bridge comment=defconf interface=sfp-sfpplus20
add bridge=bridge comment=defconf interface=sfp-sfpplus21
add bridge=bridge comment=defconf interface=sfp-sfpplus22
add bridge=bridge comment=defconf interface=sfp-sfpplus23-Uplink-1
add bridge=bridge comment=defconf interface=sfp-sfpplus24-Uplink-2
add interface=ether1 list=WAN
add interface=sfp-sfpplus1-DD4.0.1 list=LAN
add interface=sfp-sfpplus2-DD4.0.2 list=LAN
add interface=sfp-sfpplus3-DD4.0.3 list=LAN
add interface=sfp-sfpplus4-DD4.0.4 list=LAN
add interface=sfp-sfpplus5-DD5.0.1 list=LAN
add interface=sfp-sfpplus6-DD5.0.2 list=LAN
add interface=sfp-sfpplus7-DD5.0.3 list=LAN
add interface=sfp-sfpplus8-DD5.0.4 list=LAN
add interface=sfp-sfpplus9-DD6.0.1 list=LAN
add interface=sfp-sfpplus10-DD6.0.2 list=LAN
add interface=sfp-sfpplus11-DD6.0.3 list=LAN
add interface=sfp-sfpplus12-DD6.0.4 list=LAN
add interface=sfp-sfpplus13 list=LAN
add interface=sfp-sfpplus14 list=LAN
add interface=sfp-sfpplus15 list=LAN
add interface=sfp-sfpplus16 list=LAN
add interface=sfp-sfpplus17-DDPC.1 list=LAN
add interface=sfp-sfpplus18-DDPC.2 list=LAN
add interface=sfp-sfpplus19 list=LAN
add interface=sfp-sfpplus20 list=LAN
add interface=sfp-sfpplus21 list=LAN
add interface=sfp-sfpplus22 list=LAN
add interface=qsfpplus1-1 list=LAN
add interface=qsfpplus1-2 list=LAN
add interface=qsfpplus1-3 list=LAN
add interface=qsfpplus1-4 list=LAN
add interface=qsfpplus2-1 list=LAN
add interface=qsfpplus2-2 list=LAN
add interface=qsfpplus2-3 list=LAN
add interface=qsfpplus2-4 list=LAN
add interface=sfp-sfpplus23-Uplink-1 list=LAN
add interface=sfp-sfpplus24-Uplink-2 list=LAN
add address=192.168.1.10/24 comment=defconf interface=sfp-sfpplus1-DD4.0.1 \
network=192.168.1.0
add address=192.168.1.10/8 disabled=yes interface=sfp-sfpplus1-DD4.0.1 \
network=192.0.0.0
/ip dhcp-client
add disabled=yes interface=bridge
add address=192.168.1.0/24 dns-server=192.168.1.10 gateway=192.168.1.10 \
netmask=24
set servers=0.0.0.0
/system clock
set time-zone-name=Asia/Hong_Kong
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
/system swos
set address-acquisition-mode=static allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,\
p9,p10,p11,p12,p13,p14,p15,p16,p17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27\
,p28,p29,p30,p31" identity=Mikrotik-40G-Swi static-ip-address=192.168.1.6
We don’t need complex vlan or firewall settings, and we hope to just allow anything that connects to this Mikrotik SFP+ switch can be access each other’s shared folder/NAS/local network.
If anyone knows how to, please let me know!
Thanks all!
