We are facing serious performance issues with our two core switches. Even with a simple speedtest at 150Mbs from a machine, the CPU spikes to 100%.
Can someone verify below configuration please?
# 2025-12-18 17:02:52 by RouterOS 7.16.1
# software id = 30DV-NK70
# model = CRS326-24S+2Q+
# serial number = HHH0A9V9AD7
add ageing-time=3m name=Core-bridge priority=0x2000 vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] loop-protect=on
set [ find default-name=sfp-sfpplus2 ] loop-protect=on
set [ find default-name=sfp-sfpplus3 ] loop-protect=on
set [ find default-name=sfp-sfpplus4 ] loop-protect=on
set [ find default-name=sfp-sfpplus5 ] loop-protect=on
set [ find default-name=sfp-sfpplus24 ] loop-protect=on
/interface vlan
add interface=Core-bridge name=vlan150 vlan-id=150
add interface=Core-bridge name=vlan151 vlan-id=151
add interface=Core-bridge name=vlan152 vlan-id=152
add interface=Core-bridge loop-protect=on name=vlan153 vlan-id=153
add interface=Core-bridge name=vlan154 vlan-id=154
add interface=Core-bridge loop-protect=on name=vlan155 vlan-id=155
add interface=Core-bridge name=vlan156 vlan-id=156
/interface bonding
add lacp-rate=1sec mode=802.3ad name=bond-syn slaves=\
sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus11 transmit-hash-policy=\
layer-2-and-3
/interface vrrp
add comment="VRRP 150" interface=vlan150 name=VRRP150 priority=150 vrid=150
add comment=VRRP151 interface=vlan151 name=VRRP151 priority=150 vrid=151
add comment=VRRP152 interface=vlan152 name=VRRP152 priority=150 vrid=152
add comment=VRRP153 interface=vlan153 name=VRRP153 priority=150 vrid=153
add comment=VRRP154 interface=vlan154 name=VRRP154 priority=150 vrid=154
add comment=VRRP155 interface=vlan155 name=VRRP155 priority=150 vrid=155
add comment=VRRP156 interface=vlan156 name=VRRP156 priority=150 vrid=156
add name=WAN
add name=LAN
add name=VRRP
/ip dhcp-server option
add code=119 name=domain-search value=\
"0x04'froq'0x03'lan'0x0004'corp'0x04'froq'0x02'nl'0x00"
/ip dhcp-server option sets
add name=domain-search-set options=domain-search
add name=dhcp_pool2 ranges=10.10.151.20-10.10.151.254
add name=dhcp_pool3 ranges=10.10.154.50-10.10.154.254
add name=dhcp_pool4 ranges=10.10.156.10-10.10.156.254
add name=dhcp_pool5 ranges=10.10.155.10-10.10.155.254
add name=dhcp_pool6 ranges=10.10.150.10-10.10.150.253
add name=dhcp_pool7 ranges=10.10.152.10-10.10.152.254
add name=dhcp_pool8 ranges=10.10.153.10-10.10.153.254
add address-pool=dhcp_pool2 dhcp-option-set=domain-search-set interface=\
vlan151 name=dhcp1
add address-pool=dhcp_pool3 dhcp-option-set=domain-search-set interface=\
vlan154 name=dhcp2
add address-pool=dhcp_pool4 interface=vlan156 name=dhcp4
add address-pool=dhcp_pool5 dhcp-option-set=domain-search-set interface=\
vlan155 name=dhcp3
add address-pool=dhcp_pool6 interface=vlan150 name=dhcp5
add address-pool=dhcp_pool7 dhcp-option-set=domain-search-set interface=\
vlan152 name=dhcp6
add address-pool=dhcp_pool8 dhcp-option-set=domain-search-set interface=\
vlan153 name=dhcp7
/port
set 0 name=serial0
add bridge=Core-bridge comment=defconf edge=no frame-types=\
admit-only-vlan-tagged interface=qsfpplus1-1
add bridge=Core-bridge comment=defconf interface=qsfpplus1-2
add bridge=Core-bridge comment=defconf interface=qsfpplus1-3
add bridge=Core-bridge comment=defconf interface=qsfpplus1-4
add bridge=Core-bridge comment=defconf interface=qsfpplus2-1
add bridge=Core-bridge comment=defconf interface=qsfpplus2-2
add bridge=Core-bridge comment=defconf interface=qsfpplus2-3
add bridge=Core-bridge comment=defconf interface=qsfpplus2-4
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus12
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus16
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus18
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus19
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus20
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus21
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus22
add bridge=Core-bridge comment=defconf edge=no interface=sfp-sfpplus23
add bridge=Core-bridge interface=sfp-sfpplus3 point-to-point=yes
add bridge=Core-bridge interface=sfp-sfpplus4 point-to-point=yes
add bridge=Core-bridge interface=sfp-sfpplus5
add bridge=Core-bridge interface=sfp-sfpplus6
add bridge=Core-bridge edge=no interface=sfp-sfpplus1 point-to-point=yes
add bridge=Core-bridge interface=sfp-sfpplus2 point-to-point=yes
add bridge=Core-bridge interface=sfp-sfpplus7
add bridge=Core-bridge interface=sfp-sfpplus24 pvid=150
add bridge=Core-bridge interface=bond-syn pvid=151
/interface ethernet switch l3hw-settings
set icmp-reply-on-error=no ipv6-hw=yes
set discover-interface-list=all
/interface bridge vlan
# sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus11 not a bridge port
add bridge=Core-bridge tagged="Core-bridge,sfp-sfpplus5,sfp-sfpplus4,sfp-sfppl\
us1,sfp-sfpplus2,sfp-sfpplus3" untagged=\
sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus11 vlan-ids=151
add bridge=Core-bridge tagged="Core-bridge,sfp-sfpplus4,sfp-sfpplus3,sfp-sfppl\
us1,sfp-sfpplus2,sfp-sfpplus5" vlan-ids=152
us1,sfp-sfpplus2,sfp-sfpplus3" vlan-ids=153
us1,sfp-sfpplus2,sfp-sfpplus3" vlan-ids=154
us3,sfp-sfpplus1,sfp-sfpplus2" vlan-ids=155
add bridge=Core-bridge tagged=Core-bridge,sfp-sfpplus5,sfp-sfpplus3 vlan-ids=\
156
us1,sfp-sfpplus2,sfp-sfpplus5,sfp-sfpplus6" untagged=sfp-sfpplus24 \
vlan-ids=150
set 0 l3-hw-offloading=yes
add interface=ether1 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8 list=LAN
add interface=sfp-sfpplus9 list=LAN
add interface=sfp-sfpplus10 list=LAN
add interface=sfp-sfpplus11 list=LAN
add interface=sfp-sfpplus12 list=LAN
add interface=sfp-sfpplus13 list=LAN
add interface=sfp-sfpplus14 list=LAN
add interface=sfp-sfpplus15 list=LAN
add interface=sfp-sfpplus16 list=LAN
add interface=sfp-sfpplus17 list=LAN
add interface=sfp-sfpplus18 list=LAN
add interface=sfp-sfpplus19 list=LAN
add interface=sfp-sfpplus20 list=LAN
add interface=sfp-sfpplus21 list=LAN
add interface=sfp-sfpplus22 list=LAN
add interface=sfp-sfpplus23 list=LAN
add interface=sfp-sfpplus24 list=WAN
add interface=qsfpplus1-1 list=LAN
add interface=qsfpplus1-2 list=LAN
add interface=qsfpplus1-3 list=LAN
add interface=qsfpplus1-4 list=LAN
add interface=qsfpplus2-1 list=LAN
add interface=qsfpplus2-2 list=LAN
add interface=qsfpplus2-3 list=LAN
add interface=qsfpplus2-4 list=LAN
add interface=vlan150 list=LAN
add interface=vlan151 list=LAN
add interface=vlan152 list=LAN
add interface=vlan153 list=LAN
add interface=vlan154 list=LAN
add interface=vlan155 list=LAN
add interface=vlan156 list=LAN
add interface=VRRP151 list=LAN
add interface=VRRP152 list=LAN
add interface=VRRP153 list=LAN
add interface=VRRP154 list=LAN
add interface=VRRP155 list=LAN
add interface=VRRP156 list=LAN
add address=10.10.151.2/24 comment="GW VLAN151" interface=vlan151 network=\
10.10.151.0
add address=10.10.152.2/24 comment="GW VLAN152" interface=vlan152 network=\
10.10.152.0
add address=10.10.153.2/24 comment="GW VLAN153" interface=vlan153 network=\
10.10.153.0
add address=10.10.154.2/24 comment="GW VLAN154" interface=vlan154 network=\
10.10.154.0
add address=10.10.155.2/24 comment="GW VLAN155" interface=vlan155 network=\
10.10.155.0
add address=10.10.156.2/24 comment="GW VLAN156" interface=vlan156 network=\
10.10.156.0
add address=10.10.151.1/24 comment=VRRP151 interface=VRRP151 network=\
10.10.151.0
add address=10.10.152.1/24 comment=VRRP152 interface=VRRP152 network=\
10.10.152.0
add address=10.10.153.1/24 comment=VRRP153 interface=VRRP153 network=\
10.10.153.0
add address=10.10.154.1/24 comment=VRRP154 interface=VRRP154 network=\
10.10.154.0
add address=10.10.155.1/24 comment=VRRP155 interface=VRRP155 network=\
10.10.155.0
add address=10.10.156.1/24 comment=VRRP156 interface=VRRP156 network=\
10.10.156.0
add address=10.10.150.3/24 comment=VLAN150-MGMT interface=vlan150 network=\
10.10.150.0
add address=10.10.150.254/24 comment="VRRP 150" interface=VRRP150 network=\
10.10.150.0
/ip dhcp-client
add disabled=yes interface=*3A
add address=10.10.150.0/24 dns-server=10.10.151.11 gateway=10.10.150.254
add address=10.10.151.0/24 dns-server=10.10.151.11 gateway=10.10.151.1
add address=10.10.152.0/24 dns-server=10.10.151.11 gateway=10.10.152.1
add address=10.10.153.0/24 dns-server=10.10.151.11 gateway=10.10.153.1
add address=10.10.154.0/24 dns-server=10.10.151.11 gateway=10.10.154.1
add address=10.10.155.0/24 dns-server=10.10.151.11 gateway=10.10.155.1
add address=10.10.156.0/24 dns-server=10.10.151.11 gateway=10.10.156.1
set servers=202.56.230.2
add action=fasttrack-connection chain=forward comment="fasttrack established" \
connection-state=established,related disabled=yes hw-offload=yes
add action=accept chain=forward connection-state=established,related \
disabled=yes
add action=accept chain=forward comment="IT to Any" disabled=yes src-address=\
10.10.152.0/24
add action=accept chain=forward comment="HR to any" disabled=yes src-address=\
10.10.153.0/24
add action=accept chain=forward comment="Prod to servers" disabled=yes \
dst-address=10.10.151.0/24 src-address=10.10.154.0/24
add action=accept chain=forward comment="Prod to Core GW" disabled=yes \
dst-address=10.10.150.1 src-address=10.10.154.0/24
add action=accept chain=forward comment="Wifi to Core GW" disabled=yes \
dst-address=10.10.150.1 src-address=10.10.155.0/24
add action=accept chain=forward comment="Peri to server" disabled=yes \
dst-address=10.10.151.0/24 src-address=10.10.156.0/24
add action=accept chain=forward comment="Server to ANy" connection-state=\
established,related disabled=yes src-address=10.10.151.0/24
add action=accept chain=input comment="Allow VRRP (proto 112)" disabled=yes \
in-interface-list=VRRP protocol=vrrp
add action=accept chain=forward comment="Allow WiFi to Printers" disabled=yes \
dst-address=10.10.156.0/24 src-address=10.10.155.0/24
add action=accept chain=forward comment="Allow Synology Server to Camera" \
disabled=yes dst-address=10.10.156.0/24 src-address=10.10.151.0/24
add action=accept chain=forward comment="DHCP relay server" disabled=yes \
dst-port=67,68 protocol=udp
add action=accept chain=forward comment="DHCP server relay" disabled=yes \
protocol=udp src-port=67,68
add action=accept chain=forward comment="Default drop" disabled=yes
/ip hotspot profile
add dst-address=0.0.0.0/0 gateway=10.10.150.1
/ip service
set ssh address=10.10.200.0/24
set api disabled=yes
set winbox address=10.10.200.0/24,192.168.100.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Kolkata
/system identity
set name="Core 1"
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/system routerboard settings
set enter-setup-on=delete-key
/tool e-mail
set from=<mikrotik@corp.froq.nl> server=10.10.151.11 tls=starttls user=\
ict.nl@corp.froq.nl
/tool graphing
set page-refresh=never
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool sniffer
set file-name=corearp1 filter-interface=sfp-sfpplus24
