Hello there!
i would like to ask for some tipps/help on my routeros config. As im stuck with most google results tried. Current config:
add ingress-filtering=no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=Management vlan-id=200
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge interface=all
/interface bridge vlan
add bridge=bridge tagged="ether1,qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus12,sfp-sfpplus13,sfp-sfpplus14,sfp-sfpplus15,sfp-sfpplus16,sfp-sfpplus\
17,sfp-sfpplus18,sfp-sfpplus19,sfp-sfpplus20,sfp-sfpplus21,sfp-sfpplus22,sfp-sfpplus23,sfp-sfpplus24" vlan-ids=200
17,sfp-sfpplus18,sfp-sfpplus19,sfp-sfpplus20,sfp-sfpplus21,sfp-sfpplus22,sfp-sfpplus23,sfp-sfpplus24" vlan-ids=300
17,sfp-sfpplus18,sfp-sfpplus19,sfp-sfpplus20,sfp-sfpplus21,sfp-sfpplus22,sfp-sfpplus23,sfp-sfpplus24" vlan-ids=400
add address=10.100.30.1/16 interface=Management network=10.100.0.0
set servers=10.100.0.1
add disabled=no dst-address=0.0.0.0/0 gateway=10.100.0.1 routing-table=main suppress-hw-offload=no
/system clock
/system identity
set name=Test-Switch
/system routerboard settings
set boot-os=router-os
Use case for my CRS326-24S+2Q+RM with routeros 7.6:
- one default network untagged default VLAN, all ports tagged with Vlan200,300,400
- management via VLAN 200
All should go through the switching chip but it seems i got some misconfigs would be glad if someone can take me back on the road for mikrotik fun
Edit: corrected the Model
