crs326 access problem
Hi
I have a very strange problem:
I have 3 new crs326-24g-2s+rm in my network.
One of them had kernel problem, I used a console cable and netinstall to reinstall routeros on it.
After that my other computers connected to other switches can not see this switch nor computers connected to it and vice versa. I reset to defaults and I tested both routeros and swos.
I upgrade routeros to 7.11.2 and swos to 2.13 still not working.
I checked bridge configuration on routeros (all of ports are in one bridge), vlans are default (empty), and flow control was tx only but I disabled it.
Any Idea?
The config would help:
/export file=anynameyoulike
Make sure to remove serial and any other private information
Thank you for your reply
Export:
add admin-mac=35:ED:47:FB:56:C3 auto-mac=no comment=defconf name=bridge
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add address=192.168.88.10/24 comment=defconf interface=bridge network=\
    192.168.88.0
/system identity
set name=MikroTikIT
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
/system swos
set identity=MikroTikIT static-ip-address=192.168.88.10
Any suggestions?
Is the admin MAC set on bridge unique in your network?
That was it. I can’t believe it. Thank you very much.
