CRS326 Architecture
Trying to update the firmware on some CRS326-24S+2Q+RM and I’m a bit confused. The RouterOS firmware download page has the CRS3xxx series listed under the ARM architecture but WinBox is says mipsbe. I’ve checked on the specs shit and it also says mipsbe as well as the qualcomm product info spec sheet for that chip. It looks like its just a mistake on the website but I wanted to be sure before trying to update.
This CRS is Mipsbe, as you can check on website:
https://mikrotik.com/product/CRS326-24Splus2QplusRM
You can check it under ”/system resources” on your device as well.
And yes, I think it is a little bit confusing if you follow only the downloads page.
