CRS326: cannot get VLAN tagged working
I have a RouterBOARD CRS326-24G-2S+ and I’m trying to configure some VLANs, but I’m having problems.
What I need is to have two ports (ether17 and ether23) which are untagged on VLAN1 (LAN) and tagged on VLAN78 (VLAN_IOT).
I followed the guide at https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#VLAN_Example_.231_.28Trunk_and_Access_Ports.29.
All 24 ports are bridged in the Switch_LAN bridge which have VLAN filtering enabled:
[admin@switch1] /interface bridge> print detail
 0 R ;;; defconf
     name="Switch_LAN" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=48:8F:5A:87:AB:B5 protocol-mode=rstp
     fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=48:8F:5A:87:AB:B5 ageing-time=5m priority=0x8000 max-message-age=20s
     forward-delay=15s transmit-hold-count=6 vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all ingress-filtering=no
     dhcp-snooping=no
I created the VLAN 78 interface (VLAN_IOT):
[admin@switch1] /interface vlan> print detail
 0 R name="VLAN_IOT" mtu=1500 l2mtu=1588 mac-address=48:8F:5A:87:AB:B5 arp=enabled arp-timeout=auto loop-protect=default
     loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=78 interface=Switch_LAN
     use-service-tag=no
Ports 17 and 23 are added to the Switch_LAN bridge with PVID=1:
[admin@switch1] /interface bridge port> print detail
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
12   H ;;; defconf
       interface=ether17 bridge=Switch_LAN priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto
       horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no
       unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no
       multicast-router=temporary-query fast-leave=no
18   H ;;; defconf
       interface=ether23_WiFi-AP bridge=Switch_LAN priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
       learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all
       ingress-filtering=no unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no
       trusted=no multicast-router=temporary-query fast-leave=no
Ports 17 and 23 are added in the bridge VLAN configuration as tagged ports in the VLAN78:
[admin@switch1] /interface bridge vlan> print detail
Flags: X - disabled, D - dynamic
 0   bridge=Switch_LAN vlan-ids=78 tagged=ether23_WiFi-AP,ether17 untagged="" current-tagged=ether17,ether23_WiFi-AP current-untagged=""
 1 D bridge=Switch_LAN vlan-ids=1 tagged="" untagged="" current-tagged=""
     current-untagged=Switch_LAN,ether10,ether14,ether23_WiFi-AP,sfp-sfpplus1,LAG_Nas,LAG_NasBackup,ether17
The RouterBOARD has a IP address configured on the VLAN_IOT interface (192.168.78.254):
[admin@switch1] /ip address> print detail
 3   ;;; IOT Network IP Address (Default Gateway)
     address=192.168.78.254/24 network=192.168.78.0 interface=VLAN_IOT actual-interface=VLAN_IOT
If I connect a wired laptop to the port 17, configure its ethernet interface with VLAN tag 78 and configure a manual IP address on it (192.168.78.200/24) I cannot ping the RouterBOARD IP address 192.168.78.254.
Could you help me to understand where I’m wrong, please?
Thank you very much!
Bye
Fragments of the configuration are not that helpful, posting the output of /export hide-sensitive is recommended.
That said it is likely you are missing the bridge-to-CPU port under /interface bridge vlan for your VLAN 78 - should be tagged=Switch_LAN,ether23_WiFi-AP,ether17
Thanks! Now it’s working!
Thank you very much for you help!!
Bye
