CRS326 Cant set management access on vlan
I am trying to set up a management vlan on a CRS326, I want untagged traffic coming in on port ether1 to be able to access the management vlan of 100, with an ip of 192.168.86.5. I set the pvid of ether1 to 100, added vlan100 to the bridge vlan table, created the vlan and added the bridge to the vlan, I set the address on the vlan, and enabled vlan filtering on the bridge. I can not seem to get this to work though. I cant ping the address and obviously no winbox or ssh (my computer is at 192.168.86.252 and is plugged directly into ether1)
When I run
 /interface bridge vlan print
from console ether1 shows up as untaggged under vlan 100 as I’d expect.
There is something i missed somewhere that is likely glaring obvious, any suggestions?
Below is my config
# jan/02/1970 00:08:16 by RouterOS 6.47.7
# model = CRS326-24S+2Q+
add admin-mac=[i]<obfuscated for privacy>[/i] auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=MGMT vlan-id=100
/ip hotspot profile
add bridge=bridge comment=defconf interface=ether1 pvid=100
add bridge=bridge comment=defconf interface=qsfpplus1-1
add bridge=bridge comment=defconf interface=qsfpplus1-2
add bridge=bridge comment=defconf interface=qsfpplus1-3
add bridge=bridge comment=defconf interface=qsfpplus1-4
add bridge=bridge comment=defconf interface=qsfpplus2-1
add bridge=bridge comment=defconf interface=qsfpplus2-2
add bridge=bridge comment=defconf interface=qsfpplus2-3
add bridge=bridge comment=defconf interface=qsfpplus2-4
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge comment=defconf interface=sfp-sfpplus5
add bridge=bridge comment=defconf interface=sfp-sfpplus6
add bridge=bridge comment=defconf interface=sfp-sfpplus7
add bridge=bridge comment=defconf interface=sfp-sfpplus8
add bridge=bridge comment=defconf interface=sfp-sfpplus9
add bridge=bridge comment=defconf interface=sfp-sfpplus10
add bridge=bridge comment=defconf interface=sfp-sfpplus11
add bridge=bridge comment=defconf interface=sfp-sfpplus12
add bridge=bridge comment=defconf interface=sfp-sfpplus13
add bridge=bridge comment=defconf interface=sfp-sfpplus14
add bridge=bridge comment=defconf interface=sfp-sfpplus15
add bridge=bridge comment=defconf interface=sfp-sfpplus16
add bridge=bridge comment=defconf interface=sfp-sfpplus17
add bridge=bridge comment=defconf interface=sfp-sfpplus18
add bridge=bridge comment=defconf interface=sfp-sfpplus19
add bridge=bridge comment=defconf interface=sfp-sfpplus20
add bridge=bridge comment=defconf interface=sfp-sfpplus21
add bridge=bridge comment=defconf interface=sfp-sfpplus22
add bridge=bridge comment=defconf interface=sfp-sfpplus23
add bridge=bridge comment=defconf interface=sfp-sfpplus24
add bridge=bridge vlan-ids=100
add address=192.168.86.5/24 comment=defconf interface=MGMT network=\
    192.168.86.0
/system routerboard settings
set boot-os=router-os
/system swos
set allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14,p15,p16,p\
    17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27,p28,p29,p30,p31,p32" identity=\
    MikroTik
This part is incomplete:
add bridge=bridge > tagged=bridge > vlan-ids=100
Optionally it could be changed to
add bridge=bridge > tagged=bridge untagged=ether1 > vlan-ids=100
but ports with PVID set are implicitly added as untagged to appropriate VLANs.
Thank you! See it was something stupid and glaringly obvious.
