Hello everyone.
Im hoping I can get some help here.
We implemented this CRS326-24S-2Q+ switch today and added only 5 fibre based customers to it. The cpu seems pretty high especially considering its supposed to be doing hardware bridging and that the switch is only doing around 50mbps. The cpu is fluctuating between 30 - 60%. Under tools - profile it shows the high process as “management”. (but everything is forwarding and working as required)
Im concerned when we add more clients the CPU gets too busy.
We have a simple setup of a single bridge with vlan filtering and 1 management vlan on the bridge.
[admin@79r-cpt-01-sw01] > /interface/bridge/port print
Flags: I - INACTIVE; H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, PVID, PRIORITY, HORIZON
# INTERFACE BRIDGE HW PVID PRIORITY HORIZON
0 H sfp-sfpplus1-access03 bridge-single yes 3 0x80 none
1 H sfp-sfpplus2-75R-cpt-01 bridge-single yes 4 0x80 none
2 IH sfp-sfpplus3 bridge-single yes 1 0x80 none
3 IH sfp-sfpplus4 bridge-single yes 1 0x80 none
4 IH sfp-sfpplus5 bridge-single yes 1 0x80 none
5 IH sfp-sfpplus6 bridge-single yes 1 0x80 none
6 IH sfp-sfpplus7 bridge-single yes 1 0x80 none
7 IH sfp-sfpplus8 bridge-single yes 1 0x80 none
8 IH sfp-sfpplus9 bridge-single yes 1 0x80 none
9 H sfp-sfpplus10-shapiro bridge-single yes 300 0x80 none
10 H sfp-sfpplus11-planB bridge-single yes 300 0x80 none
11 H sfp-sfpplus12-IBTC bridge-single yes 300 0x80 none
12 H sfp-sfpplus13-MYGym bridge-single yes 300 0x80 none
13 H sfp-sfpplus14-Safegate bridge-single yes 300 0x80 none
14 IH sfp-sfpplus15 bridge-single yes 1 0x80 none
15 IH sfp-sfpplus16 bridge-single yes 1 0x80 none
16 IH sfp-sfpplus17 bridge-single yes 1 0x80 none
17 IH sfp-sfpplus18 bridge-single yes 1 0x80 none
18 IH sfp-sfpplus19 bridge-single yes 1 0x80 none
19 IH sfp-sfpplus20 bridge-single yes 1 0x80 none
20 IH sfp-sfpplus21 bridge-single yes 1 0x80 none
21 IH sfp-sfpplus22 bridge-single yes 1 0x80 none
22 IH sfp-sfpplus23 bridge-single yes 1 0x80 none
23 IH sfp-sfpplus24 bridge-single yes 1 0x80 none
Our config is as follows:
[admin@79r-cpt-01-sw01] > /export
# 1970-01-02 06:58:53 by RouterOS 7.14.3
# software id = RBL7-VQT4
# model = CRS326-24S+2Q+
# serial number = HCG08B1R3W8
add name=bridge-single vlan-filtering=yes
set [ find default-name=ether1 ] name="ether1-local MGMT"
set [ find default-name=qsfpplus1-1 ] disabled=yes
set [ find default-name=qsfpplus1-2 ] disabled=yes
set [ find default-name=qsfpplus1-3 ] disabled=yes
set [ find default-name=qsfpplus1-4 ] disabled=yes
set [ find default-name=qsfpplus2-1 ] disabled=yes
set [ find default-name=qsfpplus2-2 ] disabled=yes
set [ find default-name=qsfpplus2-3 ] disabled=yes
set [ find default-name=qsfpplus2-4 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=sfp-sfpplus1-access03 speed=1G-baseT-full
set [ find default-name=sfp-sfpplus2 ] name=sfp-sfpplus2-75R-cpt-01
set [ find default-name=sfp-sfpplus10 ] name=sfp-sfpplus10-shapiro
set [ find default-name=sfp-sfpplus11 ] name=sfp-sfpplus11-planB
set [ find default-name=sfp-sfpplus12 ] name=sfp-sfpplus12-IBTC
set [ find default-name=sfp-sfpplus13 ] name=sfp-sfpplus13-MYGym
set [ find default-name=sfp-sfpplus14 ] name=sfp-sfpplus14-Safegate
/interface vlan
add interface=bridge-single name=vlan251-management vlan-id=251
/interface lte apn
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge-single interface=sfp-sfpplus1-access03 pvid=3
add bridge=bridge-single interface=sfp-sfpplus2-75R-cpt-01 pvid=4
add bridge=bridge-single interface=sfp-sfpplus3
add bridge=bridge-single interface=sfp-sfpplus4
add bridge=bridge-single interface=sfp-sfpplus5
add bridge=bridge-single interface=sfp-sfpplus6
add bridge=bridge-single interface=sfp-sfpplus7
add bridge=bridge-single interface=sfp-sfpplus8
add bridge=bridge-single interface=sfp-sfpplus9
add bridge=bridge-single interface=sfp-sfpplus10-shapiro pvid=300
add bridge=bridge-single interface=sfp-sfpplus11-planB pvid=300
add bridge=bridge-single interface=sfp-sfpplus12-IBTC pvid=300
add bridge=bridge-single interface=sfp-sfpplus13-MYGym pvid=300
add bridge=bridge-single interface=sfp-sfpplus14-Safegate pvid=300
add bridge=bridge-single interface=sfp-sfpplus15
add bridge=bridge-single interface=sfp-sfpplus16
add bridge=bridge-single interface=sfp-sfpplus17
add bridge=bridge-single interface=sfp-sfpplus18
add bridge=bridge-single interface=sfp-sfpplus19
add bridge=bridge-single interface=sfp-sfpplus20
add bridge=bridge-single interface=sfp-sfpplus21
add bridge=bridge-single interface=sfp-sfpplus22
add bridge=bridge-single interface=sfp-sfpplus23
add bridge=bridge-single interface=sfp-sfpplus24
set udp-timeout=10s
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge-single tagged=bridge-single,sfp-sfpplus2-75R-cpt-01 vlan-ids=251
add bridge=bridge-single tagged=sfp-sfpplus1-access03 untagged=sfp-sfpplus10-shapiro,sfp-sfpplus11-planB,sfp-sfpplus12-IBTC,sfp-sfpplus13-MYGym,sfp-sfpplus14-Safegate vlan-ids=300
/interface ovpn-server server
set auth=sha1,md5
add address=10.10.30.20/24 interface=vlan251-management network=10.10.30.0
add disabled=no dst-address=0.0.0.0/0 gateway=10.10.30.1 routing-table=main suppress-hw-offload=no
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system identity
set name=79r-cpt-01-sw01
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
