Off hand, I don’t see a way to specify a MAC on a specific port, but you can enable port lock which locks the port to the first MAC that is connected. See the Forwarding tab.
Hi
thanks for the idea. but i have more then one MAC behind this port. Im thinking to get an hAP lite just as a bridge connected and define bridge filter rules on that box.
I know not very elegant but it might work.
Assuming that the hAP is also “just” a bridge. Would the filter then just be appplied to the forward chain or would i need to assign it also to the bridge or port itself ?
so i would implment:
