CRS326 to CRS326 low speed lan
Hi friends. I connect two crs326 together and each router connected to the HP G9 server. but the transfer of files between two servers is very slow. The speed is only 300Mb/s. There is no any firewall rules in routers and I configured fasttrack on both router.
Where the problem ?
the schematic:
G9server1----------crs326----------crs326---------G9server2
Sent from my SM-A705FN using Tapatalk
Fastrack has to do with firewall and connection tracking + fastpath that has nothing to do with a Layer2 communication which will not go through the firewall anyways…
What i would do is use iperf3 and do a speedtest between the two servers so i can be sure of the speed results…
Thanks for reply. I do it and share the result
