My crs328-24p-4s+rm can’t seem to use 10Gbps I have to set the ports to 1Gbps disabling auto negotiate.
I’m using the same DAC cables on my ccr2004-16g-2s+ and that works fine (with other devices) the connection between the two mikrotik switch/router is limited to 1Gbps, same with any other device connected to the crs328, auto negotate also fails.
DACs I have tried
3m (10ft) Brocade 10G-SFPP-TWX-P-0301 Compatible 10G SFP+ Passive Direct Attach Copper Twinax Cable
10Gtek [2 Pack 10Gb/s SFP+ DAC Cable 2m - 10GBASE-CU Passive Direct Attach Copper Twinax SFP+ Cable Compatible for Cisco SFP-H10GB-CU2M, Ubiquiti,Netgear,D-Link,Zyxel,Mikrotik,Open Switch
What info do you guys need to help me diagnose?
