Does anyone know if the subject switch SFP+ port will SYNC at 2.5G?
Recently I was asked to reconfigure a network for a client that is having Bell Canada FTTH 1.5G/940M service installed .
Apparently BELL’s ONT/SFP syncs at 2.5G for this service and I want to use MikroTik gear …
I do happen to know that the Ubiquiti ES-16-XG switch does Sync at 2.5G
My plan was to remove the patch cable and the GPON ONT SFP from the ISP’s switch/router called HH3000, and then plug them into one of the SFP+ ports on the MikroTik CRS328-24P-4S+RM
For Routing I was also planning on using the CCR1072 as the Router for this client.
I checked the MikroTik SFP module compatibility table but quite frankly is does not help me to answer the Question.
I need to do this network install end of September so before I acquire the equipment I want to be sure that it will work.
Thanks for any insight the knowledgeable reader can provide.
