CRS328-24P-4S+ Tx Drop
We have CRS328-24P-4S+ running Mikrotik version 7.10.2 we are getting Tx Drop anyone facing same issue?
Regards
Any Idea?
Sure…after you provide some additional information:
  • what version were you running before?
  • had the same problem with previous OS?
  • what is the percentage drops in regards to the traffic?
  • is it on an interface (and have you checked wire?
  • what does your config look like?
-Before we was on v6.49.8 long term.
  • Yes
    Tx Unicast: 330541201
    Tx Broadcast: 85454
    Tx Multicast: 82283
    Tx Drop: 448
    Tested on both interfaces SFP and Ethernet
    name=bridge1
    set [ find default-name=ether1 ] poe-out=off
    set [ find default-name=ether2 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether3 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether4 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether5 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether6 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether7 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether8 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether9 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether10 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether11 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether12 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether13 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether14 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether15 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether16 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether17 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether18 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether19 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether20 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether21 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether22 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether23 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=ether24 ] poe-out=forced-on poe-voltage=low
    set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no
    set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no
    set [ find default-name=sfp-sfpplus3 ] auto-negotiation=no
    set [ find default-name=sfp-sfpplus4 ] auto-negotiation=no
    /interface vlan
    add interface=bridge1 name=vlan61 vlan-id=61
    add exclude=dynamic name=discover
    /queue interface
    set ether1 queue=ethernet-default
    set ether2 queue=ethernet-default
    set ether3 queue=ethernet-default
    set ether4 queue=ethernet-default
    set ether5 queue=ethernet-default
    set ether6 queue=ethernet-default
    set ether7 queue=ethernet-default
    set ether8 queue=ethernet-default
    set ether9 queue=ethernet-default
    set ether10 queue=ethernet-default
    set ether11 queue=ethernet-default
    set ether12 queue=ethernet-default
    set ether13 queue=ethernet-default
    set ether14 queue=ethernet-default
    set ether15 queue=ethernet-default
    set ether16 queue=ethernet-default
    set ether17 queue=ethernet-default
    set ether18 queue=ethernet-default
    set ether19 queue=ethernet-default
    set ether20 queue=ethernet-default
    set ether21 queue=ethernet-default
    set ether22 queue=ethernet-default
    set ether23 queue=ethernet-default
    set ether24 queue=ethernet-default
    set sfp-sfpplus1 queue=ethernet-default
    set sfp-sfpplus2 queue=ethernet-default
    set sfp-sfpplus3 queue=ethernet-default
    set sfp-sfpplus4 queue=ethernet-default
    add bridge=bridge1 interface=ether6
    add bridge=bridge1 interface=ether7
    add bridge=bridge1 interface=ether8
    add bridge=bridge1 interface=ether9
    add bridge=bridge1 interface=ether10
    add bridge=bridge1 interface=ether11
    add bridge=bridge1 interface=ether12
    add bridge=bridge1 interface=ether13
    add bridge=bridge1 interface=ether14
    add bridge=bridge1 interface=ether15
    add bridge=bridge1 interface=ether16
    add bridge=bridge1 interface=ether17
    add bridge=bridge1 interface=ether18
    add bridge=bridge1 interface=ether19
    add bridge=bridge1 interface=ether20
    add bridge=bridge1 interface=ether21
    add bridge=bridge1 interface=ether22
    add bridge=bridge1 interface=ether23
    add bridge=bridge1 interface=ether24
    set discover-interface-list=discover
    add interface=vlan61 list=discover
    add address=10.0.61.46/24 interface=vlan61 network=10.0.61.0
    add distance=1 gateway=10.0.61.1
    /ip service
    set telnet disabled=yes
    set ftp disabled=yes
    set ssh disabled=yes
    set api disabled=yes
    set api-ssl disabled=yes
    /system routerboard settings
    set boot-os=router-os
    [admin@MikroTik] >
P.S.: Now We are downgraded the switch to v6.49.8 long term again, Ethernet 1 the main link we have very simple configuration on the switch it’s just an access switch. We are getting more TX Drop when using queue=only-hardware-queue
Regards
I seem to be seeing this same thing but on a CRS326-24G.
Similar bridge setup and tx drops. Happening on 2 switches on the SFP+ interfaces. I do see some on copper interfaces as well, but not nearly as many as the SFP+ interfaces. 65 tx drops in under 30 min of runtime. No rx drops though, rx is running clean. Just seems to be tx.
Any fix about above issue?
Tested v7.15.2 still have TX drops.
What is connected to the ports you are seeing drops in?
Out of curiosity I checked a CRS326-24G-2S+ that’s in use as a server switch here and sure enough I am seeing TX drops however only on 4 interfaces. The devices connected to these 4 interfaces are all Proxmox servers.
All 4 ports are vlan trunks. As these are the only ports on the switch with TX drops I’m inclined to think it’s a client issue rather than a switch issue and that Proxmox might be the issue.
I also have a CRS328-24P-4S+ and no ports are showing TX drops.
The CRS326 is running 7.15.2
The CRS328 is running 7.15.1
Mikrotik PowerBox’s with 100Mbps port are connected to ports.
