CRS328-24P Ports not providing Power
Been in the wild for a few weeks now. a few ports stopped providing power.
Move the devices to a nearby port and they power up.
Anyone else see this?
Support has the files
After I refused to netinstall the switch… We moved the cameras to other ports and they worked.
I sent support the files and this was the reply.
Unfortunately, it seems like there is a hardware issue with this device, and we will not be able to help remotely.
If the device is still covered by warranty, please contact the distributor or the company you bought the device from and ask for RMA warranty repair and further instructions.
You can refer to this issue number: SUP-15xxxx
Best regards
So we are attempting to get an RMA.
At least you got a reply from support…
