I have two CRS328-4C-20S-4S+ and the contractor supplied FiberStore SFP-FE-BX SFPs for hooking up a small neighborhood. There are RB960PGS routers on the other end. When we first hooked these up across the fiber, they auto-negotiated at 100M-full but passed no traffic. We set the SFP modules to 1Gbps-full without auto-negotiation. The ports go into running state only when there is two way light. On the CRS, we see TX packets but no RX packets. If I move the SFP to a sfp-sfpplus port, then set it to 1Gbps-full, we have a good link. Unfortunately, there aren’t enough sfp-plus ports.
Anyway, that proves the SFP-FE-BX’s are working. They also work in the sfp ports of a CCR1036-12G-4S and the RB960PGS, and pass 1Gbps traffic both ways.
I’ve tried RouterOS 6.44.3 and RouterOS 6.42.10. When I downgraded to 6.42.10, one (!) of the several sfp ports which should be active passed traffic! I touched it and it went away. Never came back. I’m guessing there was some sort of fluke as the CRS came up from the downgrade. I’ve been unable to reproduce. But, it appears that the SFP’s can be made to work in the CRS.
Is there anything known about issues with the FiberStore SFPs in the CRS328? Is there some data I can gather to help debug this?
Below is the SFP information for two units. Both should be up and running. There are 960PGS on the other end.
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-module-present: yes
sfp-rx-loss: no
sfp-type: SFP-or-SFP+
sfp-connector-type: SC
sfp-link-length-9um: 15000m
sfp-vendor-name: FIBERSTORE
sfp-vendor-part-number: SFP-FE-BX
sfp-vendor-serial: J170308XXXX
sfp-manufacturing-date: 17-03-10
sfp-wavelength: 1550nm
sfp-temperature: 33C
sfp-supply-voltage: 3.21V
sfp-tx-bias-current: 14mA
sfp-tx-power: -10.52dBm
sfp-rx-power: -11.398dBm
eeprom-checksum: good
eeprom: 0000: 03 04 01 00 00 02 10 00 00 00 00 02 01 00 0f 96 ........ ........
0010: 00 00 00 00 46 49 42 45 52 53 54 4f 52 45 20 20 ....FIBE RSTORE
0020: 20 20 20 20 00 00 00 00 53 46 50 2d 46 45 2d 42 .... SFP-FE-B
0030: 58 20 20 20 20 20 20 20 20 20 20 20 06 0e 00 53 X ...S
0040: 00 1a 00 00 4a 31 37 30 33 30 38 xx xx xx xx 20 ....J170 308XXXX
0050: 20 20 20 20 31 37 30 33 31 30 00 00 68 90 01 22 1703 10..h.."
0060: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0070: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0080: 5a 00 d3 00 55 00 d8 00 94 70 69 78 90 88 6d 60 Z...U... .pix..m`
0090: c3 50 00 00 af c8 00 32 07 cb 00 fb 06 31 01 3c .P.....2 .....1.<
00a0: 0c 5a 00 02 09 d0 00 03 00 00 00 00 00 00 00 00 .Z...... ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 3f 80 00 00 00 00 00 00 01 00 00 00 ....?... ........
00d0: 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 28 ........ .......(
00e0: 21 79 7d 68 1c a7 03 7f 03 ca 00 00 00 00 20 00 !y}h.... ...... .
00f0: 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff 00 ........ ........
status: link-ok
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-rx-loss: no
sfp-tx-fault: no
sfp-temperature: 26C
sfp-supply-voltage: 3.236V
sfp-tx-bias-current: 13mA
sfp-tx-power: -10.609dBm
sfp-rx-power: -11.407dBm
0050: 20 20 20 20 31 37 30 33 31 30 00 00 68 90 01 29 1703 10..h..)
00e0: 1a bc 7e 68 1b 0d 03 65 03 c8 00 00 00 00 20 00 ..~h...e ...... .
