Model CRS328-24P-4S+
Current Firmware 6.46.1
Free HDD Space 800 KiB
Total HDD Size 16.0 MiB
The main problem: Running out of disk space, when minimum 500kB is reached UM will be stopped!
The problem occurred after the attempt to import a huge address list. It’s eat all the free space and show 0 of available space. After reboot it show me ~500KB.
Configuration reset by GUI or button “reset” on switch didn’t help.
Any ideas? Is where method to empty all configuration and and reset partition content to a default factory firmware?
It is easy CRS series was not design for UM setups - use them as switches, yes there is a possibility to configure many things on them, bet the fact that it is possible, doesn’t mean that it is right thing to do.
It is best to add another device like the RB750Gr3 or when you need more routing capability in the future maybe an RB4011iGS+RM or RB1100AHx4 could be considered.
Those devices allow to add external storage via microSD card or USB stick where you can store the UM database (or in case of RB4011 and RB1100 they already come with more storage).
