Anav! Look forward to the butt kicking I’m probably about to get.
I’ll leave the bridge alone. I know you are protective of it.
I would like to be able to see the router and switches while connected on the MGMT vlan of my network. This would be via an access port using WinBox. I don’t use anything other than Winbox.
As for the configs, hold on to your butt:
RB5009
# aug/20/2022 21:05:10 by RouterOS 7.4.1
# software id = 7ZLE-935S
# model = RB5009UG+S+
# serial number =
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1_WAN
set [ find default-name=ether2 ] name=ether2_MGMT
set [ find default-name=ether5 ] name=ether5_TRUNK
set [ find default-name=ether6 ] name=ether6_MGMT
set [ find default-name=ether7 ] name=ether7_KIDS
set [ find default-name=ether8 ] name=ether8_PARENTS
set [ find default-name=sfp-sfpplus1 ] rx-flow-control=auto speed=1Gbps \
tx-flow-control=auto
/interface wireguard
add listen-port=51820 mtu=1420 name="Remote Access Wireguard"
add listen-port=51821 mtu=1420 name=Utah
add listen-port=51888 mtu=1420 name=UtahRB5009
/interface vlan
add interface=bridge1 name=CAMERAS_VLAN vlan-id=140
add interface=bridge1 name=KIDS_VLAN vlan-id=120
add interface=bridge1 name=MGMT_VLAN vlan-id=100
add interface=bridge1 name=PARENTS_VLAN vlan-id=160
add name=WAN
add name=VLANS
add name=WinAccess
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-128 lifetime=8h
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-192-cbc,aes-128-cbc,aes-128-gcm
add name=MGMT_POOL ranges=10.20.100.100-10.20.100.254
add name=KIDS_POOL ranges=10.20.120.100-10.20.120.254
add name=CAMERAS_POOL ranges=10.20.140.100-10.20.140.254
add name=PARENTS_POOL ranges=10.20.160.100-10.20.160.254
add address-pool=MGMT_POOL interface=MGMT_VLAN lease-time=1h name=MGMT_DHCP
add address-pool=KIDS_POOL interface=KIDS_VLAN lease-time=1h name=KIDS_DHCP
add address-pool=CAMERAS_POOL interface=CAMERAS_VLAN lease-time=1h name=\
CAMERAS_DHCP
add address-pool=PARENTS_POOL interface=PARENTS_VLAN lease-time=1h name=\
PARENTS_DHCP
/ppp profile
set *FFFFFFFE bridge=bridge1 use-ipv6=no
/queue type
add kind=fq-codel name=fqcodel
add kind=cake name=cake_WAN_down
add kind=cake name=cake_WAN_up
add kind=cake name=cake_VPN_down
add kind=cake name=cake_VPN_up
add kind=cake name=cake1
add kind=cake name=cake2
/queue simple
add max-limit=100M/25M name=WAN queue=cake_WAN_up/cake_WAN_down target=\
ether1_WAN total-queue=cake2
add max-limit=25M/10M name=UtahVPN queue=cake_VPN_up/cake_VPN_down target=\
Utah total-queue=cake1
add disabled=yes dst=Utah max-limit=2M/15M name=FireTVwired queue=\
fqcodel/fqcodel target=10.200.2.3/32 total-queue=fqcodel
add disabled=yes dst=Utah max-limit=2M/15M name=AppleTV queue=fqcodel/fqcodel \
target=10.200.2.5/32 total-queue=fqcodel
add disabled=yes dst=Utah max-limit=1M/5M name=KidTablet1 queue=\
fqcodel/fqcodel target=10.20.20.30/32 total-queue=fqcodel
add disabled=yes dst=Utah max-limit=1M/5M name=KidTablet2 queue=\
fqcodel/fqcodel target=10.20.20.31/32 total-queue=fqcodel
add disabled=yes dst=Utah max-limit=2M/15M name=FireTVwireless queue=\
fqcodel/fqcodel target=10.200.2.4/32 total-queue=fqcodel
/routing id
add disabled=no id=192.168.150.254 name=id-1 select-dynamic-id=only-loopback
/routing ospf instance
add disabled=no name=ospf-instance-1 router-id=id-1
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-area-1
/routing table
add disabled=no fib name=Utah
add disabled=no fib name=UtahRB5009
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether5_TRUNK
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
interface=ether6_MGMT pvid=100
interface=ether7_KIDS pvid=120
interface=ether8_PARENTS pvid=160
set enabled=yes
set discover-interface-list=WinAccess
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1,ether5_TRUNK untagged=\
ether8_PARENTS vlan-ids=160
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1,ether5_TRUNK vlan-ids=140
ether7_KIDS vlan-ids=120
ether6_MGMT vlan-ids=100
/interface detect-internet
set detect-interface-list=WAN wan-interface-list=WAN
add interface=ether1_WAN list=WAN
add interface="Remote Access Wireguard" list=VLANS
add interface=Utah list=VLANS
add interface=KIDS_VLAN list=VLANS
add interface=CAMERAS_VLAN list=VLANS
add interface=PARENTS_VLAN list=VLANS
add interface=ether2_MGMT list=WinAccess
add interface=PARENTS_VLAN list=WinAccess
add interface=MGMT_VLAN list=VLANS
add interface=MGMT_VLAN list=WinAccess
add interface="Remote Access Wireguard" list=WinAccess
add interface=Utah list=WinAccess
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=\
51821 interface=Utah persistent-keepalive=30s public-key=\
"publickey="
add allowed-address=10.103.103.2/32 interface="Remote Access Wireguard" \
"publickey="
add allowed-address=0.0.0.0/0 endpoint-address=192.168.88.13 endpoint-port=\
51888 interface=UtahRB5009 persistent-keepalive=30s public-key=\
"publickey="
add address=10.20.100.1/24 interface=MGMT_VLAN network=10.20.100.0
add address=10.20.120.1/24 interface=KIDS_VLAN network=10.20.120.0
add address=10.102.102.2/30 interface=Utah network=10.102.102.0
add address=10.103.103.1/24 interface="Remote Access Wireguard" network=\
10.103.103.0
add address=10.20.140.1/24 interface=CAMERAS_VLAN network=10.20.140.0
add address=10.20.160.1/24 interface=PARENTS_VLAN network=10.20.160.0
add address=192.168.99.1/24 interface=ether2_MGMT network=192.168.99.0
add address=10.188.188.2/30 interface=UtahRB5009 network=10.188.188.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m update-time=no
/ip dhcp-client
add interface=ether1_WAN use-peer-dns=no
/ip dhcp-server lease
add address=10.20.120.30 mac-address=10:09:F9:17:CB:1C server=KIDS_DHCP
add address=10.20.120.31 mac-address=74:E2:0C:75:AF:EB server=KIDS_DHCP
add address=10.20.120.5 mac-address=74:40:BB:AA:46:51 server=KIDS_DHCP
add address=10.20.120.40 mac-address=9C:DA:3E:AD:E1:84 server=KIDS_DHCP
add address=10.20.100.13 mac-address=F0:9F:C2:C3:16:DE server=MGMT_DHCP
add address=10.20.100.12 mac-address=80:2A:A8:DE:F4:4A server=MGMT_DHCP
add address=10.20.100.23 mac-address=74:AC:B9:B0:4C:4A server=MGMT_DHCP
add address=10.20.100.10 mac-address=74:83:C2:79:9F:3D server=MGMT_DHCP
add address=10.20.100.22 mac-address=74:AC:B9:B0:4B:EE server=MGMT_DHCP
add address=10.20.100.15 mac-address=CC:32:E5:73:FF:EE server=MGMT_DHCP
add address=10.20.100.11 mac-address=80:2A:A8:1D:A1:3F server=MGMT_DHCP
add address=10.20.100.5 mac-address=00:11:32:21:53:FD server=MGMT_DHCP
add address=10.20.120.35 client-id=1:bc:83:85:7e:a7:85 mac-address=\
BC:83:85:7E:A7:85 server=KIDS_DHCP
add address=10.20.100.71 client-id=1:b8:31:b5:92:69:d2 mac-address=\
B8:31:B5:92:69:D2 server=MGMT_DHCP
add address=10.20.100.72 client-id=1:54:8c:a0:df:b6:4b mac-address=\
54:8C:A0:DF:B6:4B server=MGMT_DHCP
add address=10.20.100.73 client-id=1:a0:78:17:a4:6f:55 mac-address=\
A0:78:17:A4:6F:55 server=MGMT_DHCP
add address=10.20.140.30 client-id=1:fc:ec:da:1f:5f:c8 mac-address=\
FC:EC:DA:1F:5F:C8 server=CAMERAS_DHCP
add address=10.20.140.31 client-id=1:fc:ec:da:1f:60:af mac-address=\
FC:EC:DA:1F:60:AF server=CAMERAS_DHCP
add address=10.20.160.73 mac-address=A0:78:17:A4:6F:55 server=PARENTS_DHCP
add address=10.20.160.4 mac-address=1C:12:B0:66:D9:F3 server=PARENTS_DHCP
add address=10.20.160.5 mac-address=F0:B3:EC:2A:09:C9 server=PARENTS_DHCP
add address=10.20.160.70 mac-address=54:8C:A0:DF:B6:4B server=PARENTS_DHCP
add address=10.20.160.71 mac-address=D6:C4:0E:9E:F7:F7 server=PARENTS_DHCP
add address=10.20.160.72 mac-address=16:7D:64:09:54:1B server=PARENTS_DHCP
add address=10.20.160.3 mac-address=60:6D:3C:17:00:FD server=PARENTS_DHCP
add address=10.20.160.74 mac-address=B8:31:B5:92:69:D2 server=PARENTS_DHCP
add address=10.20.160.75 client-id=1:5c:85:7e:35:72:af mac-address=\
5C:85:7E:35:72:AF server=PARENTS_DHCP
add address=10.20.120.32 client-id=1:b8:63:4d:b7:fe:f mac-address=\
B8:63:4D:B7:FE:0F server=KIDS_DHCP
add address=10.20.100.14 client-id=1:8:55:31:91:ad:2b mac-address=\
08:55:31:91:AD:2B server=MGMT_DHCP
add address=10.20.100.21 client-id=1:80:2a:a8:96:41:cb mac-address=\
80:2A:A8:96:41:CB server=MGMT_DHCP
add address=10.20.100.7 client-id=\
ff:33:d9:db:b6:0:2:0:0:ab:11:eb:4a:16:bc:6b:58:7a:f mac-address=\
E4:5F:01:6C:BF:AD server=MGMT_DHCP
add address=10.20.100.0/24 dns-server=10.20.100.7 domain=ooverseas.home \
gateway=10.20.100.1 ntp-server=10.20.100.1
add address=10.20.120.0/24 dns-server=10.20.100.7 domain=ooverseas.home \
gateway=10.20.120.1 ntp-server=10.20.120.1
add address=10.20.140.0/24 dns-none=yes domain=overseas.home gateway=\
10.20.140.1 ntp-server=10.20.140.1
add address=10.20.160.0/24 dns-server=10.20.100.7 domain=overseas.home \
gateway=10.20.160.1 ntp-server=10.20.160.1
add address=192.168.99.0/24 gateway=192.168.99.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip firewall address-list
add address=10.20.100.0/24 comment="Local Subnets" list="Local Subnets"
add address=10.10.1.0/24 comment="Utah Subnets" list="Utah Subnets"
add address=10.10.10.0/24 list="Utah Subnets"
add address=10.10.30.0/24 list="Utah Subnets"
add address=10.10.50.0/24 list="Utah Subnets"
add address=10.20.120.0/24 list="Local Subnets"
add address=10.20.160.0/24 list="Local Subnets"
add address=10.20.160.3 comment=Streaming list=Streaming
add address=192.168.88.0/24 list="Local Subnets"
add address=10.20.160.5 list=Streaming
add address=10.102.102.0/24 comment="Utah Wireguard" list="Utah Wireguard"
add address=10.20.120.30 list=Streaming
add address=10.20.120.31 list=Streaming
add address=10.103.103.0/24 list="Local Subnets"
add address=10.20.160.70 comment="Management devices" list=\
"Management Devices"
add address=10.103.103.0/24 list="Management Devices"
add address=10.20.140.0/24 list="Local Subnets"
add address=10.20.160.71 list="Management Devices"
add address=10.20.160.72 list="Management Devices"
add address=10.20.160.73 list="Management Devices"
add address=10.20.160.74 list="Management Devices"
add address=10.20.160.75 list="Management Devices"
add address=10.20.160.76 list="Management Devices"
add address=10.20.160.4 list=Streaming
add address=10.20.100.100-10.20.100.254 list="Management Devices"
add address=10.10.1.0/24 list="Management Devices"
add action=accept chain=input comment="allow established and related" \
connection-state=established,related log-prefix=WHAT
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="allow ICMP" protocol=icmp
add action=accept chain=input comment="allow ssh" dst-port=55512 \
in-interface=ether1_WAN protocol=tcp
add action=accept chain=input comment="remote access wireguard" dst-port=\
51820 in-interface=ether1_WAN protocol=udp
add action=accept chain=input comment="utah wireguard" dst-port=51821 \
add action=accept chain=input comment="utah wireguard" dst-port=51888 \
add action=accept chain=input comment=OSPF protocol=ospf
add action=accept chain=input comment="management devices to router" \
connection-state="" src-address-list="Management Devices"
add action=accept chain=input comment=NTP dst-port=123 in-interface-list=\
VLANS protocol=udp
add action=accept chain=input comment=DHCP dst-port=67 in-interface-list=\
VLANS protocol=udp
add action=accept chain=input comment=DNS dst-port=53 in-interface-list=VLANS \
protocol=tcp
add action=accept chain=input dst-port=53 in-interface-list=VLANS protocol=\
udp
add action=drop chain=input comment="drop everything else" log-prefix=\
"drop all"
add action=accept chain=forward comment="allow established and related" \
add action=drop chain=forward comment="drop invalid" connection-state=invalid \
log-prefix=invalid
add action=accept chain=forward comment="remote wireguard" in-interface=\
add action=accept chain=forward comment=VLANS_DNS_PIHOLE dst-address=\
10.20.100.7 dst-port=53 in-interface-list=VLANS protocol=tcp
add action=accept chain=forward dst-address=10.20.100.7 dst-port=53 \
in-interface-list=VLANS log-prefix=KidsDNS protocol=udp
add action=accept chain=forward comment="LAN firewall" in-interface=MGMT_VLAN \
log-prefix=LAN
add action=accept chain=forward comment="PARENTS firewall" dst-address-list=\
"Local Subnets" in-interface=PARENTS_VLAN log-prefix=LAN \
add action=accept chain=forward dst-address-list="Utah Subnets" in-interface=\
PARENTS_VLAN out-interface=Utah src-address-list="Management Devices"
add action=accept chain=forward dst-address=10.20.100.5 in-interface=\
PARENTS_VLAN
add action=accept chain=forward in-interface=PARENTS_VLAN log-prefix=LAN \
out-interface=ether1_WAN
add action=accept chain=forward comment="PARENTS streaming" in-interface=\
PARENTS_VLAN log-prefix=streaming out-interface=Utah
add action=accept chain=forward comment="KIDS streaming" in-interface=\
KIDS_VLAN log-prefix=streaming out-interface=Utah src-address-list=\
Streaming
add action=accept chain=forward comment="Kids Internet" in-interface=\
KIDS_VLAN out-interface=ether1_WAN
add action=accept chain=forward comment="Cameras firewall" dst-address=\
10.20.100.10 in-interface=CAMERAS_VLAN log-prefix=cameras_NVR
add action=drop chain=forward comment="drop everything else" log-prefix=\
"drop all"
/ip ipsec policy
set 0 dst-address=10.10.50.0/24 src-address=10.200.2.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Utah routing-table=\
Utah scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=55512
set api disabled=yes
set winbox port=56473
set api-ssl disabled=yes
/ip smb shares
add comment="default share" directory=/pub name=pub
/ip smb users
add name=guest
/ip ssh
set always-allow-password-login=yes strong-crypto=yes
/ipv6 firewall address-list
/routing ospf interface-template
add area=ospf-area-1 disabled=no interfaces=Utah type=ptp
add area=ospf-area-1 disabled=no interfaces=\
CAMERAS_VLAN,KIDS_VLAN,PARENTS_VLAN,MGMT_VLAN passive
/routing rule
add action=lookup disabled=no src-address=10.20.100.7/32 table=main
add action=lookup disabled=no dst-address=10.20.100.7/32 src-address=\
0.0.0.0/0 table=main
add action=lookup-only-in-table disabled=no interface=PARENTS_VLAN \
src-address=10.20.160.3/32 table=Utah
src-address=10.20.160.4/32 table=Utah
src-address=10.20.160.5/32 table=Utah
add action=lookup-only-in-table disabled=no interface=KIDS_VLAN src-address=\
10.20.120.30/32 table=Utah
10.20.120.31/32 table=Utah
/snmp
set enabled=yes trap-target=0.0.0.0
/system clock
set time-zone-autodetect=no time-zone-name=Asia/Kuwait
/system identity
set name=Overseas_RB5009
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=1.pool.ntp.org
add address=0.pool.ntp.org
/system routerboard reset-button
set enabled=yes hold-time=30s..0s
/tool bandwidth-server
set enabled=no
/tool graphing
set store-every=24hours
/tool mac-server
set allowed-interface-list=WinAccess
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool sniffer
set filter-interface=Utah
CRS328
# aug/18/2022 22:00:36 by RouterOS 7.4.1
# software id = H7RS-H84M
# model = CRS328-24P-4S+
# serial number =
add name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-TRUNK poe-out=off poe-priority=1
set [ find default-name=ether2 ] poe-out=off
set [ find default-name=ether3 ] name=ether3-RB5009
set [ find default-name=ether4 ] poe-out=off
set [ find default-name=ether5 ] name=ether5-LtAP
set [ find default-name=ether6 ] poe-out=off
set [ find default-name=ether7 ] name=ether7-SG5100
set [ find default-name=ether8 ] poe-out=off
set [ find default-name=ether9 ] poe-out=off
set [ find default-name=ether10 ] poe-out=off
set [ find default-name=ether11 ] poe-out=off
set [ find default-name=ether12 ] poe-out=off
set [ find default-name=ether13 ] poe-out=off
set [ find default-name=ether14 ] poe-out=off
set [ find default-name=ether15 ] poe-out=off
set [ find default-name=ether16 ] poe-out=off
set [ find default-name=ether17 ] name=ether17_downstairs
set [ find default-name=ether18 ] poe-out=off
set [ find default-name=ether19 ] poe-out=off
set [ find default-name=ether20 ] poe-out=off
set [ find default-name=ether21 ] name=ether21-NAS poe-out=off
set [ find default-name=ether22 ] name=ether22-AP
set [ find default-name=ether23 ] name=ether23-AP
set [ find default-name=ether24 ] name=ether24-CK
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-TRUNK
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1-TRUNK
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether3-RB5009 pvid=5
interface=ether5-LtAP pvid=5
interface=ether10 pvid=100
add bridge=bridge interface=ether16
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether22-AP
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether23-AP
interface=ether24-CK pvid=100
add bridge=bridge frame-types=admit-only-vlan-tagged interface=\
sfp-sfpplus1-TRUNK
add bridge=bridge interface=ether2
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether4
add bridge=bridge interface=ether6
interface=ether7-SG5100 pvid=5
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether11
add bridge=bridge interface=ether12
add bridge=bridge interface=ether13
add bridge=bridge interface=ether14
add bridge=bridge interface=ether15
ether17_downstairs
add bridge=bridge interface=ether18
add bridge=bridge interface=ether19
interface=ether21-NAS pvid=100
add bridge=bridge interface=ether20
add bridge=bridge interface=sfp-sfpplus2
add bridge=bridge interface=sfp-sfpplus3
add bridge=bridge interface=sfp-sfpplus4
/ipv6 settings
set disable-ipv6=yes
add bridge=bridge tagged="sfp-sfpplus1-TRUNK,ether22-AP,ether23-AP,ether1-TRUN\
K,ether17_downstairs,bridge" vlan-ids=100
add bridge=bridge tagged="ether23-AP,ether22-AP,ether17_downstairs,ether1-TRUN\
K,bridge,sfp-sfpplus1-TRUNK" vlan-ids=120
add bridge=bridge tagged=\
bridge,ether1-TRUNK,ether17_downstairs,sfp-sfpplus1-TRUNK vlan-ids=140
add bridge=bridge tagged="bridge,ether1-TRUNK,ether17_downstairs,ether22-AP,et\
her23-AP,sfp-sfpplus1-TRUNK" vlan-ids=160
/ip dhcp-client
/ip service
set ssh port=55512
/ip ssh
set strong-crypto=yes
/system identity
set name=CRS328
/system ntp client
set enabled=yes
/system routerboard settings
set boot-os=router-os
/system swos
set allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14,p15,p16,p\
17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27,p28" allow-from-vlan=100 \
identity=CRS328 static-ip-address=10.20.100.14
