i have problem with my configuration. My switch works like a hub.
EQ. When i ping 2 servers, from third tshark can see that packets.
Can Yuu help with that case?
# mar/21/2020 19:12:08 by RouterOS 6.45.8
# software id = IIHG-S4TB
# model = CRS354-48G-4S+2Q+
# serial number = B8450B37B913
add add-dhcp-option82=yes comment="SWITCHING BRIDGE" dhcp-snooping=yes \
igmp-snooping=yes name=bridge priority=0x2000 vlan-filtering=yes
set [ find default-name=ether1 ] comment=host1-1
set [ find default-name=ether2 ] comment=host1-2 mac-address=C4:AD:34:A2:31:24
set [ find default-name=ether3 ] comment=host2-1
set [ find default-name=ether4 ] comment=host2-2 mac-address=C4:AD:34:A2:31:26
set [ find default-name=ether5 ] comment=host3-1
set [ find default-name=ether6 ] comment=host3-2 mac-address=C4:AD:34:A2:31:28
set [ find default-name=ether7 ] comment=host4-1
set [ find default-name=ether8 ] comment=host4-2 mac-address=C4:AD:34:A2:31:2A
set [ find default-name=ether9 ] comment=host5-1
set [ find default-name=ether10 ] comment=host5-2 mac-address=C4:AD:34:A2:31:2C
set [ find default-name=ether11 ] comment=host6-1
set [ find default-name=ether12 ] comment=host6-2 mac-address=C4:AD:34:A2:31:2E
set [ find default-name=ether13 ] comment=host7-1
set [ find default-name=ether14 ] comment=host7-2 mac-address=C4:AD:34:A2:31:30
set [ find default-name=ether15 ] comment=host8-1
set [ find default-name=ether16 ] comment=host8-2 mac-address=C4:AD:34:A2:31:32
set [ find default-name=ether17 ] comment=host9-1
set [ find default-name=ether18 ] comment=host9-2 mac-address=C4:AD:34:A2:31:34
set [ find default-name=ether19 ] comment=host10-1
set [ find default-name=ether20 ] comment=host10-2 mac-address=\
C4:AD:34:A2:31:36
set [ find default-name=ether21 ] disabled=yes
set [ find default-name=ether22 ] disabled=yes
set [ find default-name=ether23 ] disabled=yes
set [ find default-name=ether24 ] disabled=yes
set [ find default-name=ether25 ] disabled=yes
set [ find default-name=ether26 ] disabled=yes
set [ find default-name=ether27 ] disabled=yes
set [ find default-name=ether28 ] disabled=yes
set [ find default-name=ether29 ] disabled=yes
set [ find default-name=ether30 ] disabled=yes
set [ find default-name=ether31 ] disabled=yes
set [ find default-name=ether32 ] disabled=yes
set [ find default-name=ether33 ] disabled=yes
set [ find default-name=ether34 ] disabled=yes
set [ find default-name=ether35 ] disabled=yes
set [ find default-name=ether36 ] disabled=yes
set [ find default-name=ether37 ] disabled=yes
set [ find default-name=ether38 ] disabled=yes
set [ find default-name=ether39 ] disabled=yes
set [ find default-name=ether40 ] disabled=yes
set [ find default-name=ether41 ] disabled=yes
set [ find default-name=ether42 ] disabled=yes
set [ find default-name=ether43 ] disabled=yes
set [ find default-name=ether44 ] disabled=yes
set [ find default-name=ether45 ] disabled=yes
set [ find default-name=ether46 ] disabled=yes
set [ find default-name=ether47 ] disabled=yes
set [ find default-name=ether48 ] comment=WAN loop-protect=on
set [ find default-name=ether49 ] comment="MGMT LINK"
set [ find default-name=qsfpplus1-2 ] disabled=yes
set [ find default-name=qsfpplus1-3 ] disabled=yes
set [ find default-name=qsfpplus1-4 ] disabled=yes
set [ find default-name=qsfpplus2-1 ] mac-address=C4:AD:34:A2:31:18
set [ find default-name=qsfpplus2-2 ] disabled=yes
set [ find default-name=qsfpplus2-3 ] disabled=yes
set [ find default-name=qsfpplus2-4 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus2 ] disabled=yes
set [ find default-name=sfp-sfpplus3 ] disabled=yes
set [ find default-name=sfp-sfpplus4 ] disabled=yes
/interface bonding
add min-links=1 mode=802.3ad name=bonding-host1 slaves=ether1,ether2
add min-links=1 mode=802.3ad name=bonding-host2 slaves=ether3,ether4
add min-links=1 mode=802.3ad name=bonding-host3 slaves=ether5,ether6
add mode=802.3ad name=bonding-host4 slaves=ether7,ether8
add mode=802.3ad name=bonding-host5 slaves=ether9,ether10
add mode=802.3ad name=bonding-host6 slaves=ether11,ether12
add mode=802.3ad name=bonding-host7 slaves=ether13,ether14
add mode=802.3ad name=bonding-host8 slaves=ether15,ether16
add mode=802.3ad name=bonding-host9 slaves=ether17,ether18
add mode=802.3ad name=bonding-host10 slaves=ether19,ether20
add lacp-rate=1sec mode=802.3ad name=bonding-switch-trunk slaves=\
qsfpplus1-1,qsfpplus2-1
set 1 storm-rate=50
set 2 storm-rate=10
set 3 storm-rate=10
set 4 storm-rate=10
set 5 storm-rate=50
set 6 storm-rate=10
set 7 storm-rate=10
set 8 storm-rate=10
set 9 storm-rate=10
set 10 storm-rate=10
set 11 storm-rate=10
set 12 storm-rate=10
set 13 limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=25
set 14 limit-unknown-multicasts=yes limit-unknown-unicasts=yes storm-rate=25
set 15 storm-rate=25
set 16 storm-rate=25
set 17 storm-rate=25
set 18 storm-rate=25
set 19 storm-rate=10
set 20 storm-rate=10
set 21 storm-rate=10
set 22 storm-rate=10
set 23 storm-rate=10
set 24 storm-rate=10
set 25 storm-rate=10
set 26 storm-rate=10
set 27 storm-rate=10
set 28 storm-rate=10
set 29 storm-rate=10
set 30 storm-rate=10
set 31 storm-rate=10
set 32 storm-rate=10
set 33 storm-rate=10
set 34 storm-rate=10
set 35 storm-rate=10
set 36 storm-rate=10
set 37 storm-rate=10
set 38 storm-rate=10
set 39 storm-rate=10
set 40 storm-rate=10
set 41 storm-rate=10
set 42 storm-rate=10
set 43 storm-rate=10
set 44 storm-rate=10
set 45 storm-rate=10
set 46 storm-rate=10
set 47 storm-rate=10
set 48 storm-rate=10
set 49 storm-rate=10
set 50 storm-rate=10
set 51 storm-rate=10
set 52 storm-rate=10
set 53 storm-rate=10
set 54 storm-rate=10
set 55 storm-rate=10
set 56 storm-rate=10
set 57 storm-rate=10
set 58 storm-rate=10
set 59 storm-rate=10
set 60 storm-rate=50
set 61 storm-rate=10
/ip hotspot profile
add bridge=bridge comment=WAN interface=ether48
add bridge=bridge interface=bonding-switch-trunk internal-path-cost=1 \
path-cost=1
add bridge=bridge broadcast-flood=no interface=bonding-host1
add bridge=bridge broadcast-flood=no interface=bonding-host2
add bridge=bridge broadcast-flood=no edge=yes interface=bonding-host3
add bridge=bridge interface=bonding-host4
add bridge=bridge interface=bonding-host5
add bridge=bridge interface=bonding-host6
add bridge=bridge interface=bonding-host7
add bridge=bridge interface=bonding-host8
add bridge=bridge interface=bonding-host9
add bridge=bridge interface=bonding-host10
set discover-interface-list=none
/interface bridge vlan
add bridge=bridge comment="CEPH NETWORK" tagged="bonding-host1,bonding-host2,bon\
ding-host3,bonding-host4,bonding-host5,bonding-host6,bonding-host7,bonding-h\
ost8,bonding-host9,bonding-host10,bonding-switch-trunk,bridge" vlan-ids=999
add bridge=bridge untagged="ether1,ether2,ether3,ether4,ether5,ether6,qsfpplus1-\
1,qsfpplus2-1,bonding-switch-trunk,bonding-host1,bonding-host2,bonding-host3\
" vlan-ids=1
add address=192.168.10.251/24 interface=bridge network=192.168.10.0
set servers=1.1.1.1,8.8.8.8
add distance=1 gateway=192.168.10.254
add comment="W\B3\B9cza\E6 tylko podczas aktualizacji ROS" distance=1 gateway=\
192.168.40.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=AtmanSwitch2
/system ntp client
set enabled=yes primary-ntp=194.146.251.100 secondary-ntp=194.146.251.101
/system package update
set channel=long-term
/system routerboard settings
set boot-os=router-os
#error exporting /system swos
