Im having a issue with the CRS354-48P-4S+2Q+ series, where when i change the L2MTU values of all my ethernet to 9000, my bridge doesnt adjust to the same values, if i disable vlan filtering and enable vlan filtering on the switch then it adjusts to the same values as the ethernets, but as soon as the switch reboots then values change back to 1584 for my bridge
is this a known issue? is it being worked on or?
https://cdn.discordapp.com/attachments/651911235150938127/863193174335291402/unknown.png
