CRS354 Proper Export
I have two of these CRS354-48G-4S-2Q+ Switches running on RouterOS 6.49.6
I have /interface ethernet switch port-isolation for isolated ports
when I export the configuration from root, routerOS is not exporting the port isolation configuration
Is it something normal?
when I am at /
export command do not show the switch port isolation configuration
when I am at /interface ethernet switch port-isolation
export command shows my port isolation configuration
little bug?
Seems to be long standing bug too, from what I could find.
Just did a test on a ROS7 device, same problem still to be found there.
Best to create a support ticket to support@mikrotik.com.
I’ve seen other posts where this was also suggested and also there a support ticket was created but I did not see any response (from what I could find, maybe it’s there but pretty good hidden then).
When you keep knocking on the door, someone will answer, sooner or later :laughing:
