this is our configuration from our CRS354 switch, why is the CPU only running at 100%?
# may/13/2023 08:32:54 by RouterOS 7.6
# software id = 0PP4-P4QA
# model = CRS354-48P-4S+2Q+
# serial number = B5621FD89A64
add name=BRIDGE protocol-mode=none vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no rx-flow-control=\
auto tx-flow-control=auto
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no rx-flow-control=\
set [ find default-name=sfp-sfpplus3 ] auto-negotiation=no rx-flow-control=\
set [ find default-name=sfp-sfpplus4 ] auto-negotiation=no rx-flow-control=\
/interface vlan
add comment=MGT interface=BRIDGE name=VLAN_99 vlan-id=99
add comment=COMPANY interface=BRIDGE name=VLAN_100 vlan-id=100
add comment=GUEST interface=BRIDGE name=VLAN_200 vlan-id=200
add comment=DMZ interface=BRIDGE name=VLAN_300 vlan-id=300
add comment=HOTSPOT interface=BRIDGE name=VLAN_400 vlan-id=400
add comment=PRIVAT interface=BRIDGE name=VLAN_500 vlan-id=500
add comment=LTE interface=BRIDGE name=VLAN_600 vlan-id=600
add comment=BACKUP1 interface=BRIDGE name=VLAN_700 vlan-id=700
add comment=BACKUP2 interface=BRIDGE name=VLAN_800 vlan-id=800
add comment=TEL interface=BRIDGE name=VLAN_900 vlan-id=900
add comment=IOT interface=BRIDGE name=VLAN_1000 vlan-id=1000
add comment=PRINTER interface=BRIDGE name=VLAN_1100 vlan-id=1100
add comment=SONOS interface=BRIDGE name=VLAN_1200 vlan-id=1200
add comment=KAMERA interface=BRIDGE name=VLAN_1300 vlan-id=1300
add comment=SONSTIGES01 interface=BRIDGE name=VLAN_1400 vlan-id=1400
add comment=SONSTIGES02 interface=BRIDGE name=VLAN_1500 vlan-id=1500
add comment=SONSTIGES03 interface=BRIDGE name=VLAN_1600 vlan-id=1600
add comment=SONSTIGES04 interface=BRIDGE name=VLAN_1700 vlan-id=1700
add comment=SONSTIGES05 interface=BRIDGE name=VLAN_1800 vlan-id=1800
add comment=SONSTIGES06 interface=BRIDGE name=VLAN_1900 vlan-id=1900
add comment=SONSTIGES07 interface=BRIDGE name=VLAN_2000 vlan-id=2000
/ip hotspot profile
/port
set 0 name=serial0
/snmp community
add addresses=192.168.111.0/24,10.16.0.0/16,10.99.0.0/16 \
authentication-protocol=SHA1 encryption-protocol=AES name=snmpv3 \
security=private
add bridge=BRIDGE interface=ether1 pvid=100
add bridge=BRIDGE interface=ether2 pvid=100
add bridge=BRIDGE interface=ether3 pvid=100
add bridge=BRIDGE interface=ether4 pvid=100
add bridge=BRIDGE interface=ether5 pvid=100
add bridge=BRIDGE interface=ether6 pvid=100
add bridge=BRIDGE interface=ether7 pvid=100
add bridge=BRIDGE interface=ether8 pvid=100
add bridge=BRIDGE interface=ether9 pvid=100
add bridge=BRIDGE interface=ether10 pvid=100
add bridge=BRIDGE interface=ether11 pvid=100
add bridge=BRIDGE interface=ether12 pvid=100
add bridge=BRIDGE interface=ether13 pvid=100
add bridge=BRIDGE interface=ether14 pvid=100
add bridge=BRIDGE interface=ether15 pvid=100
add bridge=BRIDGE interface=ether16 pvid=100
add bridge=BRIDGE interface=ether17 pvid=100
add bridge=BRIDGE interface=ether18 pvid=100
add bridge=BRIDGE interface=ether19 pvid=100
add bridge=BRIDGE interface=ether20 pvid=100
add bridge=BRIDGE interface=ether21 pvid=100
add bridge=BRIDGE interface=ether22 pvid=100
add bridge=BRIDGE interface=ether23 pvid=100
add bridge=BRIDGE interface=ether24 pvid=100
add bridge=BRIDGE interface=ether25 pvid=100
add bridge=BRIDGE interface=ether26 pvid=100
add bridge=BRIDGE interface=ether27 pvid=100
add bridge=BRIDGE interface=ether28 pvid=100
add bridge=BRIDGE interface=ether29 pvid=100
add bridge=BRIDGE interface=ether30 pvid=100
add bridge=BRIDGE interface=ether31 pvid=100
add bridge=BRIDGE interface=ether32 pvid=100
add bridge=BRIDGE interface=ether33 pvid=100
add bridge=BRIDGE interface=ether34 pvid=100
add bridge=BRIDGE interface=ether35 pvid=100
add bridge=BRIDGE interface=ether36 pvid=100
add bridge=BRIDGE interface=ether37 pvid=100
add bridge=BRIDGE interface=ether38 pvid=100
add bridge=BRIDGE interface=ether39 pvid=100
add bridge=BRIDGE interface=ether40 pvid=100
add bridge=BRIDGE interface=ether41 pvid=100
add bridge=BRIDGE interface=ether42 pvid=100
add bridge=BRIDGE interface=ether43 pvid=100
add bridge=BRIDGE interface=ether44 pvid=100
add bridge=BRIDGE interface=ether45 pvid=100
add bridge=BRIDGE interface=ether46 pvid=100
add bridge=BRIDGE interface=ether47 pvid=100
add bridge=BRIDGE interface=ether48 pvid=100
add bridge=BRIDGE interface=ether49 pvid=100
add bridge=BRIDGE interface=qsfpplus1-1
add bridge=BRIDGE interface=qsfpplus1-2
add bridge=BRIDGE interface=qsfpplus1-3
add bridge=BRIDGE interface=qsfpplus1-4
add bridge=BRIDGE interface=qsfpplus2-1
add bridge=BRIDGE interface=qsfpplus2-2
add bridge=BRIDGE interface=qsfpplus2-3
add bridge=BRIDGE interface=qsfpplus2-4
add bridge=BRIDGE interface=sfp-sfpplus1
add bridge=BRIDGE interface=sfp-sfpplus2
add bridge=BRIDGE interface=sfp-sfpplus3
add bridge=BRIDGE interface=sfp-sfpplus4
/interface bridge vlan
add bridge=BRIDGE tagged=\
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=400
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=500
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=600
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=700
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=800
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=900
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1000
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1100
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1200
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1300
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1400
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1500
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1600
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1700
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1800
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=1900
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=2000
BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=300
add bridge=BRIDGE tagged="BRIDGE,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sf\
pplus4,qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplu\
s2-2,qsfpplus2-3,qsfpplus2-4" vlan-ids=99
s2-2,qsfpplus2-3,qsfpplus2-4" vlan-ids=100
/ip dhcp-client
add interface=VLAN_99
add disabled=yes interface=VLAN_100
add disabled=yes interface=VLAN_500
/snmp
set enabled=yes location=London \
trap-community=snmpv3 trap-version=3
/system clock
set time-zone-name=Europe/London
/system identity
set name=APV01SW02
/system routerboard settings
set boot-os=router-os
/tool romon
set enabled=yes
