I’m currently a little bit in trouble to set up the VLAN configuration on the new CRS3XX switches. Usually (e.g. on a CRS212) we defined the necessary 802.1ad tags (820 as vlan-id, 80 as service-id) on an access port via
To explain my use case a bit more: We are using a lot of CRS (e.g. CRS212-1G-10S-1S+) and mark the incoming traffic with a defined vlan-id for the customer and a defined service-id for the carrier. This works like a charm. Any other things I tried (e.g. creating a vlan-interface with use-service-tag and a bridge) were working more or less, but always results in software bridging which isn’t an option.
As soon as you set vlan-protocol=802.1ad, then all VLAN tagging, untagging and filtering is done by checking VLAN tag with Ethertype=0x88A8 (SVID), all CVID tags are ignored and considered as untagged traffic. Selective QinQ currently is not supported on CRS3xx.
Also note that by setting vlan-protocol=802.1ad, you are enabling all VLAN related functions (including options in /interface ethernet switch) to use SVID tags globally. This means that ACL rules will only add a SVID tag or match a SVID tag.
Thank you for clarifying the current q-in-q (or better q-or-q ) implementation in the CRS3XX switches. I thought I misunderstood the documentation. It’s a bit disappointing because the new CRS are great devices.
Can we interpret your statement as Selective QinQ will be supported in the future?
Rewriting Ingress/Egress S-VLAN and C-VLAN is absolutely essential for my use. I had planned to use the 3XX series switches in my datacentres. This may be a dealbreaker.
Are the ‘new’ switch rules also handled by the switch chip or offloaded to the CPU?
