I’ve been using and enjoying Mikrotik Routers for a while.I decided to change my switches with Mikrotik Switches.
I have a setups like following;
Main Router —> SW1 —> End_Switches
I have multiple VLAN for End_Switches and would like to configure them properly. What I want is the connection between Main_Router to SW1 should pass all VLANs. From SW1 to End_Switches I want to do Port Based VLAN and I believe its done in Bridge section.
So lets say;
Main Router → vlan id : 1 → SW1 (ether1 to ether1)
SW1 should only allow VLAN10 to SW2 (ether2 to ether2)
SW1 should allow VLAN10,20,30 to SW3 (ether3 to ether3)
SW1 should only allow VLAN 40 to SW4 (ether4 to ether4)
What I did is (assuming all ports added to bridge with hw=yes);
add bridge=bridge1 interface=ether1 pvid=1
add bridge=bridge1 interface=ether2 pvid=10
add bridge=bridge1 interface=ether3 pvid=20
add bridge=bridge1 interface=ether4 pvid=40
/interface bridge vlan
add bridge=bridge1 tagged=ether3 vlan-ids=10,20,30
add name=bridge1 vlan-filtering=yes
With this configuration, I couldn’t get it work. Is there anything am i missing?
