CRS3xx VLAN configuration
Hello to everybody.
I’m trying to configure this scenario,
Switch Cisco ----sfp-sfpplus3 CRS3XX LACP link---- Switch Cisco
All traffic arrive to CR3xx tagged, i.e. with VLAN ID 200.
So, my problem is that packets are not forwarding in the CRS3xx, I can see packets with VLAN tag ingressing sfp-sfpplus3 but not egressing LACP,
That’s is a capture from CRS3xx,
[admin@MKTSW1] > /tool sniffer quick interface=sfp-sfpplus3
INTERFACE                                                    TIME    NUM DIR SRC-MAC           DST-MAC           VLAN   SRC-ADDRESS                         DST-ADDRESS                         PROTOCOL   SIZE CPU FP
sfp-sfpplus3                                                0.229      1 ->  48:8F:5A:C1:13:39 01:80:C2:00:00:00        802.2        53   1 no
sfp-sfpplus3                                                0.657      2 <-  00:1E:F7:67:32:E0 FF:FF:FF:FF:FF:FF 200    192.168.200.1: who has 192.168.2...                                     arp          64   1 no
sfp-sfpplus3                                                2.229      3 ->  48:8F:5A:C1:13:39 01:80:C2:00:00:00        802.2        53   1 no
sfp-sfpplus3                                                2.656      4 <-  00:1E:F7:67:32:E0 FF:FF:FF:FF:FF:FF 200    192.168.200.1: who has 192.168.2...                                     arp          64   1 no
[admin@MKTSW1] > /tool sniffer quick interface=LACP1
LACP1                                                       1.019      1 ->  48:8F:5A:C1:13:37 01:80:C2:00:00:00        802.2        53   1 no
LACP1                                                       3.018      2 ->  48:8F:5A:C1:13:37 01:80:C2:00:00:00        802.2        53   1 no
LACP1                                                       5.019      3 ->  48:8F:5A:C1:13:37 01:80:C2:00:00:00        802.2        53   1 no
If I ping from one side, you can see ARP in VLAN 200 traffic ingress trought sfp-sfpplus3 but no egress
LACP Bonding interface is up and running.
That’s is my config,
add auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=sfp-sfpplus3 ] auto-negotiation=no
/interface bonding
add mode=802.3ad name=LACP1 slaves=sfp-sfpplus1,sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge comment=defconf interface=sfp-sfpplus5
add bridge=bridge comment=defconf interface=sfp-sfpplus6
add bridge=bridge comment=defconf interface=sfp-sfpplus7
add bridge=bridge comment=defconf interface=sfp-sfpplus8
add bridge=bridge interface=LACP1
/interface bridge vlan
add bridge=bridge untagged=LACP1,sfp-sfpplus3 vlan-ids=200
add address=192.168.88.2/24 comment=defconf interface=ether1 network=192.168.88.0
set servers=8.8.8.8
add distance=1 gateway=192.168.88.254
/system identity
set name=MKTSW1
any ideas?
Thank you in advance.
Assuming you want the traffic to be forwarded between sfp-sfpplus3 and the LAG tagged, the record for vlan-ids=200 in /interface bridge vlan must have the ports on the tagged list, not on the untagged one.
Thank you sindy, I can’t believe my fault… sorry.
However, I change the config and trying again but it still not works…
I disable the LACP to simply the troubleshooting.
Switch Cisco ----sfp-sfpplus3 CRS3XX sfp-sfpplus2---- Switch Cisco
That’s the config now,
/interface bonding
add disabled=yes mode=802.3ad name=LACP1 slaves=sfp-sfpplus1
add bridge=bridge interface=sfp-sfpplus2
add bridge=bridge tagged=sfp-sfpplus3,sfp-sfpplus2 vlan-ids=200
set servers=8.8.8.8
/system identity
set name=MKTSW1
/system routerboard settings
set boot-os=router-os
[admin@MKTSW1] > /tool sniffer quick interface=sfp-sfpplus2
sfp-sfpplus2                                                1.358      1 ->  48:8F:5A:C1:13:38 01:80:C2:00:00:00        802.2        53   0 no
sfp-sfpplus2                                                3.364      2 ->  48:8F:5A:C1:13:38 01:80:C2:00:00:00        802.2        53   0 no
sfp-sfpplus2                                                5.362      3 ->  48:8F:5A:C1:13:38 01:80:C2:00:00:00        802.2        53   0 no
sfp-sfpplus3                                                0.497      1 <-  00:1E:F7:67:32:E0 FF:FF:FF:FF:FF:FF 200    192.168.200.1: who has 192.168.2...                                     arp          64   1 no
sfp-sfpplus3                                                1.378      2 ->  48:8F:5A:C1:13:39 01:80:C2:00:00:00        802.2        53   0 no
sfp-sfpplus3                                                2.497      3 <-  00:1E:F7:67:32:E0 FF:FF:FF:FF:FF:FF 200    192.168.200.1: who has 192.168.2...                                     arp          64   1 no
sfp-sfpplus3                                                3.372      4 ->  48:8F:5A:C1:13:39 01:80:C2:00:00:00        802.2        53   0 no
[admin@MKTSW1] > interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1592      10218 48:8F:5A:C1:13:3F
 1  X  sfp-sfpplus1                        ether            1500  1592      10218 48:8F:5A:C1:13:37
 2  RS sfp-sfpplus2                        ether            1500  1592      10218 48:8F:5A:C1:13:38
 3  RS sfp-sfpplus3                        ether            1500  1592      10218 48:8F:5A:C1:13:39
 4   S sfp-sfpplus4                        ether            1500  1592      10218 48:8F:5A:C1:13:3A
 5   S sfp-sfpplus5                        ether            1500  1592      10218 48:8F:5A:C1:13:3B
 6   S sfp-sfpplus6                        ether            1500  1592      10218 48:8F:5A:C1:13:3C
 7   S sfp-sfpplus7                        ether            1500  1592      10218 48:8F:5A:C1:13:3D
 8   S sfp-sfpplus8                        ether            1500  1592      10218 48:8F:5A:C1:13:3E
 9  X  LACP1                               bond             1500 65535            00:00:00:00:00:00
10  R  ;;; defconf
       bridge                              bridge           1500  1592            48:8F:5A:C1:13:3F
[admin@MKTSW1] > /interface bridge port monitor 0,7
              interface: sfp-sfpplus3    sfp-sfpplus2
                 status: in-bridge       in-bridge
            port-number: 1               7
                   role: designated-port designated-port
              edge-port: yes             no
    edge-port-discovery: yes             yes
    point-to-point-port: yes             yes
           external-fdb: no              no
           sending-rstp: yes             yes
               learning: yes             yes
             forwarding: yes             yes
       hw-offload-group: switch1         switch1
Just for the case, I’d disable also the row in /interface bridge port which makes the LAG a member of the bridge (someone here had an issue with a disabled EoIP affecting the MTU of the bridge, so disabling the membership should be a safer way).
Other than that, your export suggests that you have the default setting of protocol-mode on the bridge, so maybe RSTP is blocking one of the ports or both. So what does /interface bridge monitor bridge show, and what does /interface bridge port monitor 0,1,2,3 after /interface bridge port print show?
And last, what RouterOS version do you run? Someone else here has reported 6.47.4 to break hardware VLAN filtering on an 8227 chip which worked for him with an older ROS version, maybe there is some more generic error there.
Thank you sindy.
I was using 6.47.4 but after your advise I’m using 6.46.7 long term. The issue still persist…
Unused ports are now disabled and LACP deleted.
[admin@MKTSW1] > export hide-sensitive
# jan/14/1970 22:19:12 by RouterOS 6.46.7
# software id = Z2N5-V8B0
# model = CRS309-1G-8S+
# serial number = ------
add admin-mac=48:8F:5A:C1:13:3F auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus4 ] disabled=yes
set [ find default-name=sfp-sfpplus5 ] disabled=yes
set [ find default-name=sfp-sfpplus6 ] disabled=yes
set [ find default-name=sfp-sfpplus7 ] disabled=yes
set [ find default-name=sfp-sfpplus8 ] disabled=yes
/ip hotspot profile
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge interface=sfp-sfpplus3
set servers=8.8.8.8
/system identity
set name=MKTSW1
/system package update
set channel=long-term
And that’s the output of some comands,
[admin@MKTSW1] > interface bridge monitor bridge
                     ;;; defconf
                  state: enabled
    current-mac-address: 48:8F:5A:C1:13:3F
            root-bridge: yes
         root-bridge-id: 0x8000.48:8F:5A:C1:13:3F
         root-path-cost: 0
              root-port: none
             port-count: 2
  designated-port-count: 2
           fast-forward: no
[admin@MKTSW1] >  /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H sfp-sfpplus3        bridge        yes    1     0x80         10                 10       none
 1   H sfp-sfpplus2        bridge        yes    1     0x80         10                 10       none
[admin@MKTSW1] >  /interface bridge port monitor 0,1
            port-number: 2               1
              edge-port: yes             no
           external-fdb: no              no
               learning: yes             yes
             forwarding: yes             yes
hope this help, thank you.
Edit:
I see the same behavior with untagged traffic.
RouterOs creates a Dynamic interface for VLAN 1,
[admin@MKTSW1] > interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE                                                           VLAN-IDS  CURRENT-TAGGED                                                           CURRENT-UNTAGGED
 0   bridge                                                           200       sfp-sfpplus3
        sfp-sfpplus2
 1 D bridge                                                           1        bridge
        sfp-sfpplus3
        sfp-sfpplus2
I can see an ARP request ingressin switch via sfp3 but nothing egressing via sfp2.
Stop. We’re most likely hunting for a ghost here. Hardware “acceleration” is enabled at both ports, so the traffic between them is forwarded by the switch chip, bypassing the CPU, hence the CPU cannot sniff it.
The frames you can see in the sniffer output are there because they are either sent by the CPU itself or they have a broadcast destination MAC address so the switch broadcasts them also to the CPU port.
To see whether the traffic passes from one port to the other as forwarded by the switch chip itself, you have to sniff externally.
Yes! you are right again. I will check it and return with the results.
Thank you!
