CRS418-8P-8G-2S+5axQ2axQ-RM wifi 2.4 not working
I have a new CRS418-8P-8G-2S+5axQ2axQ-RM with the default configuration.
If I disable the 5 GHz WiFi to force clients to connect only to the 2.4 GHz network, it doesn’t work – the 2.4 GHz radio keeps restarting continuously.
  • 5 GHz works fine
  • 2.4 GHz does not work (radio is looping / restarting / can’t auth)
Could this be a bug, or am I missing something in the configuration?
Thanks!
It depends ... this is a rather new device so most likely not a lot have experience with it.
Does log show anything about this restarting / looping/ ... ?
It would help if you show the actual config.
Terminal
/export file=anynameyouwish
Move to PC, edit file and remove serial, obfuscate public IP, passwds, public key, ...
Post file back here between < / > quotes.
Can you also (just to be sure) show what packages are installed ?
thx for reply here is the full export:
[admin@OOB1] > /export
2025-12-03 17:32:55 by RouterOS 7.20.4
software id = 5J2Y-R0JP
model = CRS418-8P-8G-2S+5axQ2axQ
serial number = < redacted >
add admin-mac=04:F4:1C:82:D9:2E auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=OOB1 disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=OOB1 disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/disk
set usb1 media-interface=bridge media-sharing=yes smb-sharing=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.255.100-192.168.255.200
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/disk settings
set auto-media-interface=bridge auto-smb-sharing=yes
add bridge=bridge comment=defconf edge=yes interface=ether2
add bridge=bridge comment=defconf edge=yes interface=ether3
add bridge=bridge comment=defconf edge=yes interface=ether4
add bridge=bridge comment=defconf edge=yes interface=ether5
add bridge=bridge comment=defconf edge=yes interface=ether6
add bridge=bridge comment=defconf edge=yes interface=ether7
add bridge=bridge comment=defconf edge=yes interface=ether8
add bridge=bridge comment=defconf edge=yes interface=ether9
add bridge=bridge comment=defconf edge=yes interface=ether10
add bridge=bridge comment=defconf edge=yes interface=ether11
add bridge=bridge comment=defconf edge=yes interface=ether12
add bridge=bridge comment=defconf edge=yes interface=ether13
add bridge=bridge comment=defconf edge=yes interface=ether14
add bridge=bridge comment=defconf edge=yes interface=ether15
add bridge=bridge comment=defconf edge=yes interface=ether16
add bridge=bridge comment=mgmt edge=yes interface=ether17
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge comment=defconf edge=yes interface=sfp-sfpplus1
add bridge=bridge comment=defconf edge=yes interface=sfp-sfpplus2
add interface=ether1 list=WAN
add address=192.168.255.1/24 comment=defconf interface=bridge network=192.168.255.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.255.9 client-id=1:48:a9:8a:77:b1:f mac-address=48:A9:8A:77:B1:0F server=defconf
add address=192.168.255.10 client-id=1:48:a9:8a:77:ae:6f mac-address=48:A9:8A:77:AE:6F server=defconf
add address=192.168.255.0/24 comment=defconf dns-server=192.168.255.1 domain=router.lan gateway=192.168.255.1 netmask=24 ntp-server=192.168.255.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,1.0.0.1,8.8.4.4
/ip dns static
add address=192.168.255.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=*** list=external_access
add action=accept chain=input dst-port=80 log=yes protocol=tcp src-address-list=external_access
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat disabled=yes dst-port=3389 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.255.201 to-ports=3389
add action=dst-nat chain=dstnat disabled=yes dst-port=3389 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.255.202 to-ports=3389
/ip tftp
add read-only=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=OOB1
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
add address=time.google.com
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
Not really default config, I see you added some things on dst nat and port forward. Why ? For what purpose ?
What if you really use default config ?
To be sure...
As you can see, the current setup does not use the default configuration. Although I will not be using the default settings in production, I tested with them to ensure the issue was not caused by my custom configuration, I just replicated the issues also with default config.
I that case the only thing you can do now is create supout.rif and shoot in a support ticket with your problem description.
At first sight I don't see anything odd on wifi part.
After updating to RouterOS version 7.20.5, the 2.4 GHz Wi-Fi has started working again.
Thx, Mikrotik. :slight_smile:
