I have a CRS504-4XQ-IN.
I connected it with a CRS354 over 40G DAC cable.
To do that I set qsfp28-4-1 to qsfp28-4-4 to 10G each, disable auto-negotiation
Now I want to connect a linux server using 100G. I got an Intel E810 and the linux drivers installed.
However on the RouterOS side I only get no link, on the Linux side I get
enp9s0f1: Invalid link configuration.
Would I need to set all of the 4 ports (qsfp28-3-1 to qsfp28-3-4) to 25G each? Is that correct?
I tried the mikrotic DAC and a cisco-compatible DAC and I am unsure on where to look for the problem.
Hi, i have the same Problem with E810 NICs.
I have test with MikroTik DAC, Intel DAC ans various QSFP28 Transceiver.
Between NICs and between Switches, all DAC ANF Trasceiver Works fine.
Have multiple Intel E810-CQDA2 NICs, some have this issue where direct connections between NICs work but not to the CRS504, but not all of them. Not sure if that’s due to a difference in firmware version or something else.
