I just purchased a CRS504-4XQ switch upgraded to 7.20.6 to connect seven PCs that all have Mellanox ConnectX5 cards (running current FW 16.35.8002). There are three that are connected via copper Mellanox cables at 100Gb and they work great. They can run RDMA all day configured at 100Gb without issue.
I intend on having the other four PCs connect at 25Gb via a Mikrotik XQ+BC00003-XS+ break-out cable which I purchased with the switch. But of course those are SFP connectors at 25Gb which then need to go into the ConnectX5’s QSFP connector.
Alas, I went for something cheaper than Mikrotik’s XQ+CM0000-XS converters so I bought four 10Gtek WADQS-28 adapters (https://www.10gtek.com/products/QSA-381.html) to transition from SFP connector on pigtail to the ConnectX5 QSFP. They sure look to me like they do the same thing.
To cut to the chase, it’s not working. Before I get too far into all the settings I’ve tried in WinBox to set each channel to 25Gb, let me just ask: Is this supposed to work? If so then I will go buy a XQ+CM0000-XS converter to make sure it’s not the cheaper converters before I continue mucking about with the config.
I suspect that the answer is “no, those SFP to QSFP adapters are for going into the switch only and it’s not supported to go from an SFP connector off of the pigtail into a QSFP connector in the NIC”. Hope that isn’t the answer but figured I’d ask before investing a couple hundred dollars in the Mikrotik adapters.
With the cables and cable adapter cost escalating, I probably should have just spent the bucks for the CRS520-4XS-16XQ to go 100Gb across the board.
So I won’t post any WinBox or ConnectX configuration settings I’ve tried until someone says “yes in theory that should work”.
Does anyone have any experience getting a Mellanox ConnectX5 card working off of a Mikrotik switch where the cable coming from the switch into the NIC was SPF 25Gb and then using a Mikrotik XQ+CM0000-XS connector on the NIC such it fits into the QSPF slot and runs at 25Gb?
It seems the answer is “nobody has used it in this way”. I will just revert back to using the 4 ports as they were intended which is at 100Gb and keep the other three nodes on my old 10Gb SFP switch with Mellanox SFP to QSFP cables which work fine to the connectx5s.
I believe the simplest and least expensive solution would be to swap the ConnectX 5 with a ConnectX 4 mcx4121a-ACAT (or the single port mcx4111a) SFP28. These are inexpensive and work great. I have this setup working reliably with the CRS504.
Please note that Auto negotiation doesn’t work and the speed has to be set manually to 25Gbps for each one of the four ports connected to the breakout cable.
Interesting that the cards are much cheaper than the QSFP to SFP adapters (which says more about the age of the cards than anything else). I need to buy four of them but they are roughly $35-$50 on ebay so it’s better than trying the mikrotik’s adapters. That’s not a bad way to go. Thanks!
Followup here on this. I purchased a Mellanox MAM1Q00A-QSA28 100G to 25G adapter and it works great with the Mikrotik pig tail cable. Decided not to go the ConnectX 4 route as the adapters were slightly less money and I don’t need any more NICs. Now that I know it works I’ll go buy three more and call it good. Lesson learned: care needs to be taken when dealing with SFP adapters as they are not all the same.
