Hi, I couldn't find the maximum power consumption / cooling capacity for the qsfp56-dd port.
I would like to run this switch with these / similar modules:
CRS812-8DS-2DQ-2DDQ-RM has a total power budget of 100W for all optical modules.
Since you are deploying higher-wattage optics, I would suggest keeping an eye on their temperatures during operation to ensure they remain within safe limits.
Thank you very much for the reply; the power consumption of these QSFP-DDs is approximately 23W, but I plan to use only one module with such high power consumption in the switch.
Can you think of any other problem I might run into? Thank you in advance.
