Cryptography settings in RouterOS
Hi
I have a quick question regarding cryptography settings in RouterOS. When you expose for example web interface over HTTPS it uses the following set of ciphers (as tested against v6.29.1):
Accepted  TLSv1  256 bits  AES256-SHA
Accepted  TLSv1  256 bits  CAMELLIA256-SHA
Accepted  TLSv1  128 bits  AES128-SHA
Accepted  TLSv1  128 bits  CAMELLIA128-SHA
Accepted  TLSv1  128 bits  RC4-SHA
Accepted  TLSv1  128 bits  RC4-MD5
Accepted  TLSv1  112 bits  DES-CBC3-SHA
Accepted  TLSv1  56 bits   DES-CBC-SHA
Web interface is just an example in this case, but the problem I see here is the default configuration and as far as I can tell there’s no way to tune/enable/disable specific settings here.
56-bit key length and single-DES are red flags for me - this is no longer considered secure at all I’m afraid. This key length can be factored in almost real time. I would very much like to ditch the ‘backwards compatibility’ or shall we call it ‘awkward compatibility’ if possible and disable anything with DES, RC4 and MD5 in the name as well as anything with keys shorter than 128bit.
Ok, you may say I’m picky, but there are scenarios where using Mikrotik would be ideal solution, but formal security requirements will rule it out based on the fact I can’t disable weak crypto - like it happens in more corporate settings :frowning:
So my questions (in random order) are:
  • is there a way to fine-tune the crypto settings (something I missed)?
  • is there any plan on RouterOS roadmap to include options for fine-tuning of cipher suites?
  • are there any plans to introduce TLSv1.2?
  • what is the core crypto library used in RouterOS?
Regards
Tom
