CSR112 how to configure as switch
I have a CSR112-8P-4s that is now setup as a switch/router with vlans on a bridge interface.
I want to change that to a config that is using the switch chip.
I tried to follow RouterOS - RouterOS - MikroTik Documentation but its driving me nuts.
Can someone please help me to change this config???
thanks,
Dennis
jan/03/1970 03:02:57 by RouterOS 6.47.1
software id = WVBL-ZJA5
model = CRS112-8P-4S
serial number = 9B200B6190DB
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add name=BASE
/ip hotspot profile
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=ether1 pvid=10
ingress-filtering=yes interface=ether2 pvid=10
ingress-filtering=yes interface=ether3 pvid=20
ingress-filtering=yes interface=ether4 pvid=20
ingress-filtering=yes interface=ether5 pvid=30
add bridge=BR1 frame-types=admit-only-vlan-tagged ingress-filtering=yes
interface=ether8
interface=sfp9
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=ether7
ingress-filtering=yes interface=sfp10
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=
ether6 pvid=99
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 tagged=ether8,sfp9,ether7 untagged=ether1,ether2 vlan-ids=10
add bridge=BR1 tagged=ether8,ether7,sfp9 untagged=ether3,ether4 vlan-ids=20
add bridge=BR1 tagged=ether8,ether7,sfp9 untagged=ether5,ether6 vlan-ids=30
add bridge=BR1 tagged=BR1,ether8,ether7,sfp9 vlan-ids=99
add ports=ether6 vlan-id=1
add interface=BASE_VLAN list=BASE
add address=192.168.88.2/24 interface=BASE_VLAN network=192.168.88.0
add distance=1 gateway=192.168.88.1
/system identity
set name=Switch
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
I’ve Already solved this.
My config if someone is having the same problems.
latetest-router.txt (4.72 KB)
Switch-Vlan-hardware.txt (1.37 KB)
