CSS106-1G-4P-1S Switch Restarts on SNMP Discovery
We have a number of CSS106 switches which we are monitoring with LibreNMS with SNMP v2 ReadOnly.
LibreNMS is running with default config, ie polling is every 5 minutes and discovery is every 6 hours.
Every 6 hours the switches reboot and the network drops.
We have found out that the module responsible for this is fbd-table, when we disable this module the switches are fine and do not reboot.
We have tested this with SWOS versions 2.2 -->2.7 all with the same result.
We have kept it disabled and we dont think we need it monitored anyway if its going to cause these problems.
So why do you think this happens?
