today I got my CSS318-16G-2S+ and I trying to get one of the SFP+ Ports working at least. It is my first MikroTik Switch with SwOS. I have experience with RouterOS and other MikroTik products.
I've tried two MikroTik S+85DLC03D , one MikroTik S-R1 and two third Party 10G Fiber SFP+ Modules.
All these SFP(+) Modules are working in other MikroTik routers and switches.
All these SFP(+) Modules are shown/recognized in both SFP+ Ports under the SFP-Tab in SwOS.
But no Module is able to establish a link, not with Auto Negotiation, not with manual speed settings, not with Flow Control disabled. The LEDs of both SFP+ ports are staying dark and unter the Link Tab, "no link" is always shown.
I have no more guesses or ideas what could be wrong, especially after I tried every possible port/setting combination, which is done quite fast with SwOS.
Could it be simply a defective unit?
PS.: SwOS is 2.18 and I've resetted the switch two times already.
PPS.: The other switch, a CRS226-24G-2S+, is reporting that the 10G link is established and is sending data to the CSS318-16G-2S+ switch, but is recieving zero data back. I can confirm, that I can enable and disable the SFP+ Ports of the CSS318-16G-2S+ Switch under the Link Tab, which is recognized correspondly on the CRS226-24G-2S+ side.
Solved:
The fault was on the CRS226-24G-2S+ side. It seems that the first SFP+ port is partially defective after a module died in this port. Simply switching the module to the second SFP+ port solved the issue.
