CSS326-24G-2S+RM Management & Ping reachability bug
I’ve purchased a CSS326-24G-2S+RM (running version 2.10) and the switch is not accessible at random times (Web Management or ping).
I have several other devices at the same location which do NOT have this problem (meaning it’s not a network problem). Devices connected to the switch are reachable and I’ve not noticed any obvious issues. The problem is only related to being able to get to the web interface and being able to ping the unit. When it does respond to network requests (web management and/or ping) it works just fine… but minutes later it will be inaccessible again until a few min later. This creates a problem with reliably monitoring this switch…
I think the new method of not needing to specify a proper subnet and gateway is not working well at all. Why can’t we set up the management IP/Subnet/Gateway like we have always done?
Mikrotik, any bug fix on this issue coming our way?
JB
Observe port errors for collisions, late collisions and deferred packets.
Mikrotik swos have great stability problems.
For example, autonego fallback to halfduplex.
After some time whole switch goes offline (mgmt)
