CSS326-24G-2S+RM Question
Does the CSS326-24G-2S+RM support 2x 10Gb SFP+ ?
I also have a spare SFP+ transceiver but I am unsure if it is compatible with Mirkotik.
https://www.cdw.com/shop/products/Proline-SFP-transceiver-module-10-Gigabit-Ethernet/3027740.aspx
Any help would be greatly appreciated.
It is a basic L2 24 port Gigabit Ethernet + 2x 10Gb SFP+ switch that’ll handle simple functions. If you aren’t doing any L3 or LACP this should be a great low power option.
As for the compatibility issue, you should directly ask Mirkotik rep, I don’t use cdw transceivers for my routers. Sorry
We have not tested any CDW transceivers, but judging by specifications in that webpage they should be compatible with our devices.
