Hey!
I just bought a CSS326-24G-2S+RM, It has fresh RouterOS I didn’t configure anything yet just plugged it and I can’t get more than 25Mb/s
- All ports are on the same bridge
- Connected ether1 into my ISP router
- I’m using Cat7
- Low CPU%
I spent lot of time trying to configure it but nothing. I’m desesperate rn
You mean CRS ? CSS is a SWOS only device.
What is your testing method ?
That ether1 which is interface labeled mgmt/boot on the device sits on another switchchip (atheros) connected to the mgmt-cpu.
Your bridge (and you should only have one) will act on the marvell switchchip to which you must add all interfaces except for that mgmt/boot one.
Thats the case on CRS326-24S+2Q+RM and by the look of the blockdiagram it seems to be the same on CSS326-24G-2S+RM:
CRS326-24S+2Q+RM
https://cdn.mikrotik.com/web-assets/product_files/CRS326-24S2Q_230231.png
Edit: Uhm, nevermind. CSS326-24G-2S+RM only runs SWOS so things might be different there:
https://mikrotik.com/product/CSS326-24G-2SplusRM
CSS326-24G-2S+RM seems to be a SWOS only device:
While CRS326-24S+2Q+RM can do both SWOS and RouterOS:
https://mikrotik.com/product/crs326_24s_2q_rm
CSS is SWOS only device and CRS is i think dual boot.
@OP, @Apachez provided you with block diagram. If you have CRS device dont use MGMT port for nothing else.
If your ISP router dont have sfp then use RJ-01 i think, sfp to rj45.
