The switch came with SwitchOS Lite 2.16, are there any newer or older firmware versions where this is fixed? Or do anyone else have the same problem?
I have tested with multiple SFP + modules and they all work fine if link speed is manually set to 1G.
Check out my reply: http://forum.mikrotik.com/t/does-the-css610-8g-2s-sfp-port-with-s-rj10-support-2-5gbe-speed/163642/1
Seems it is not selectable yet. You can rely only on the other side port config as of now.
Aha, thanks! So the only thing I would have to do to get it working is to set the speed manually to 10G on the device the switch is connected to?
I would be happy to upgrade my CSS610-8G-2S+IN to 2.16 because the latest firmware on the download page is 2.14 from 2021. How can I get it?
