My requirement is single-line multiplexing
my system 2.14
PPPOE vlan is 2
iptv vlan is 3
port 1 is strict only tag, its role is trunk vlan2 and vlan3
port 2 is strict only untag vlan2
port 3 is strict only untag vlan3
I use Router or computer access port 2 can get pppoe ip after dialing, but cannot connect to the Internet. I am sure there is a problem with vlan, how can I solve it?
If router can get IP address via PPPoE, then VLAN 2 on CSS is configured just fine.
Internet on router is another thing. If your router is Mikrotik as well and at (pretty much) default configuration, then interface pppoe-out1 has to be member of WAN interface list (or else NAT etc. won’t work).
